Part Needed
Old Dec 30, 2009 | 12:20 PM
Part Needed
The GTX needs its bushings replaced in the leaf springs. Where the leaf springs connects to the body, the pivot bushing is worn out there. Chrysler made a special tool for this job. Does anyone have it or know where to get it?
Old Dec 30, 2009 | 05:28 PM
John Van's Avatar
Hey, I'm lazy so I always just bring the springs to a machine shop and have them do it. How often do you change the bushings any way. just my .02 worth.
Old Dec 30, 2009 | 06:57 PM
Crazy4Carz.Com's Avatar
Makes a mess but you can "burn" them out. angle grinder and a hammer and force them out. replace with pollygraphite then you don't need any special tool.
Old Dec 31, 2009 | 12:17 AM
theomahamoparguy's Avatar
yeah, what he said (C4C)!!
Old Dec 31, 2009 | 12:42 PM
6fury4's Avatar
Member
I did my 64 with a home made tool using threaded rod, nuts and washers. I takes some figuring out that's a little too complex and wordy for me to put in print, but it's do-able. You will need air power and patience though. Give it some thought and it will come to you. You will need a big socket that will bear against the spring loop, but allow the bushing to start out
Old Jan 1, 2010 | 08:00 AM
thanks
i thought of that
i'll probably go that route
Old Jan 8, 2010 | 08:33 PM
tool.pdf
circled is the needed tool
Old Jan 9, 2010 | 06:01 AM
Torch it! There is nothing like the smell of burning rubber in the morning to get you going!
Old Jan 9, 2010 | 07:37 AM
haha
does the above link work?
Old Jan 13, 2010 | 07:13 AM
MrOldart2U's Avatar
Originally Posted by 67 GTX
haha
Yup it did for me...
Old Jan 13, 2010 | 11:39 AM
BuckNeccid's Avatar
One trick I discovered when trying to get the outer bushing sleeve out, like upper control arms and such, is to use an air hammer/chisel once you've burned the rubber out. Sure works good, I've even used it on the lower bushings.
Old Jan 13, 2010 | 12:26 PM
old tired rebel's Avatar
Attachment 1772
Thanks for that pdf file. I made a copy since this is something I will have to do.
mopmop
Jul 11, 2012 08:06 PM
MStep94765
Mar 8, 2012 10:03 PM
lugnut
Jan 2, 2008 12:37 PM
Commando
Dec 31, 2007 03:50 PM
mbroadhead
Dec 21, 2007 09:58 PM
