Please decode
Old Nov 13, 2018 | 07:10 PM
mxkurt's Avatar
Please decode
Thanks for the great help on this forum.I am in need of decoding the VIN.I tried web sites and came up empty.I think it reads m14bf56017600.If you see my error please correct me.Thanks.Kurt.
Old Nov 13, 2018 | 07:14 PM
mxkurt's Avatar
Trying picture again.
Old Nov 20, 2018 | 04:05 PM
BookGeek's Avatar
Hi! Is there any way you can maybe post a little clearer picture? It's hard to make out some of what it says!
Old Nov 20, 2018 | 04:14 PM
mxkurt's Avatar
It is my only picture.I took it at the junk yard about 40 miles away.Perhaps you may help me without the vin.Will a 1975 1/2 ton 318ci/727 bolt right up to my 1977 w200 318/727 transfer case?
Old Nov 20, 2018 | 04:22 PM
BookGeek's Avatar
Okay what I deciphered from that picture is that the VIN is W14BF5S047600 which would make this truck a 1975 Dodge W10 Conventional Cab with Sweptline box. If you would like to know any more information about this vehicle I can help you find some.
Old Nov 20, 2018 | 04:30 PM
mxkurt's Avatar
Will this 1975 1/2 ton 318ci/727 bolt right up to my 1977 w200 318/727 transfer case?
Thank you for identifying this truck.
Old Nov 20, 2018 | 04:33 PM
Motor, yes
transmission, no
Old Nov 20, 2018 | 04:40 PM
mxkurt's Avatar
Thank you.I was wrong.I thought only the axles and springs were different.I'm still learning.Thanks to you fine folks.
Old Nov 21, 2018 | 08:16 PM
mxkurt's Avatar
Uncle.
Why won't the w100 727 bolt up to my w200 transfer case?
Old Nov 22, 2018 | 06:11 AM
The output shaft and tail housing are different between the two.
Old Nov 22, 2018 | 07:28 AM
mxkurt's Avatar
So Dodge used one transfer case for the w100 and a somewhat different one for the w200?
Old Nov 22, 2018 | 07:33 AM
So both trans are 4wd?
Old Nov 22, 2018 | 07:37 AM
mxkurt's Avatar
Yes.
I own a 1977 w200 318/727 4x4 FT
WTB a 1975 w100 318/727 4x4 FT
Old Nov 22, 2018 | 09:42 AM
Sorry I was thinking that it was a 2wd transmission you wanted to use in a 4x4. That question is asked here alot.
Old Nov 22, 2018 | 03:35 PM
NP203 (Full Time Transfercase 1975-1979) should swap out without any issues....... Just my 2 cent.
IF your trying to use the NP205 in place of the NP203 without knowing your doing so???, then your trying to mismatch parts, That will be the issue.
Old Nov 23, 2018 | 07:27 AM
mxkurt's Avatar
Hi.Yes.
Just wanting to know if I can buy the 1975 W100 318/727 motor and transmission only and bolt it on to my 1977 w200 318/727 transfer case?
Old Nov 23, 2018 | 10:41 AM
Sounds like your "good to go"...
Old Nov 23, 2018 | 01:38 PM
mxkurt's Avatar
Thanks a bunch for the great advice that I get here.It is really great you guys chip in here on this site.
I agree with others that say "rebuild what you have"But just checking a few things on my engine and trans has convinced myself that there is not much left to rebuild.I'm afraid from experience that I do not have rebuild-able cores.1st "non racing" 727 I've seen destroyed.
Anyway thanks.
Please have a great day.
TTYL
Kurt.
Old Nov 23, 2018 | 02:42 PM
Keep us posted.....
Your welcome...
NicholasDM
Feb 23, 2019 01:11 AM
neckless
Feb 4, 2019 10:49 AM
ks114
Mar 23, 2018 02:33 PM
Bleueyes
Sep 14, 2010 10:30 AM
robocop1971
Aug 29, 2010 02:51 PM
