*******Please Help***** Distributor electrical question 318****************
Old Sep 23, 2008 | 12:30 AM
before you go changing parts, have you checked the hold down bolt? maybe its a little loose and the dizzy turned messing up the timing?
Old Sep 23, 2008 | 07:42 AM
Commando's Avatar
It could have turned a few degrees, might want to check the timing, do you have a light? As most of us know the place not to start solving a problem is in the wallet.
Old Sep 23, 2008 | 01:25 PM
Monacoman's Avatar
My 318 backfired and somehow set my timing 180 which bent my rods so start with your timing and if you have a dead cylinder rods might be a possibility
Old Sep 24, 2008 | 09:17 AM
I friend of mine had an 86 ramcharger that had the same problem and it turned out to be that the timing chain somehow skipped two teeth. the motor was all stock as well.
Old Sep 24, 2008 | 09:56 AM
Commando's Avatar
How many miles you got on it, as I see it jumping teeth is if it has a lot of miles on it with more wear?
I pulled the gear and chain off a motor with 38,000 miles on it, stock chain had negligible slack in it, so not sure where the slack starts to really be a factor.
If I were you and the distributor would appear to not have moved then I would check the timing chain. Otherwise if it was loose I would check the timing manually with the mark on the harmonic balancer and see if it lines up with the cylinder being at the top of its stroke. Just my advice unless you want to go pull all the stuff off the front of the engine.
Mr442
Jul 14, 2013 09:25 PM
70Coronet
May 7, 2012 06:48 AM
USMC85RD
Mar 25, 2012 09:23 AM
bobbylap
Feb 24, 2010 05:14 PM
