seized engine
Old Nov 24, 2010 | 12:35 AM
teedeej340's Avatar
seized engine
I have a seized 340 that I bought and I was wondering what is the best way of freeing the pistons. I heard of people adding Marvins Miracle Oil or transmission fluid to the cylinders, or is there something else that works better? Also one of the pistons might be rusted. Does Marvins Miracle Oil work on rust too or should I apply penetrating oil?
Old Nov 24, 2010 | 03:14 AM
If you have rust, then use a penatrating oil. Make sure to spray it once in the morning and again in the afternoon (at least every 12 hours) for a couple of days. This will allow the oil to really penatrate the rust and make it much easier to free the pistons without scoring the cylinders walls.
Since the pistons are rusted, make sure to take a close look at the cylinder walls, you may need to bore them to get any scratches out of them.
Old Nov 24, 2010 | 04:10 AM
teedeej340's Avatar
thanks for the info
Old Nov 24, 2010 | 04:49 AM
rr69half6bbl's Avatar
Tee,after a few days of the pen. oil. use a breaker bar andturn the crank just a little bit at a time in both directions to free up the stuck piston. If your gonna rebild the motor, then take the good pistons out to free up alot of the moving resistance.
Old Nov 24, 2010 | 04:53 AM
Good points!
Old Nov 24, 2010 | 02:48 PM
tracktor312's Avatar
I just pulled my 273 apart what i had to do was soak it good with marvel mystery oil a couple days. Then I had to remove the crank and tap the pistons in a little with a 2x4 then I honed the cylinders a little till I could get the pistons out! if the walls are rusted it will more than likely need to be bored out.
Old Nov 24, 2010 | 03:06 PM
Polaradude's Avatar
Deisel works well also.
Old Nov 24, 2010 | 11:08 PM
chlngr1970's Avatar
I used PB Blaster in mine. Let it soak a couple days, then added more. Let that soak a few more days, then went after freed it up with a breaker bar on the crank...back and forth as stated above. Once the piston was free, then I took a pickle fork and a brake drum and pounded it out. Block goes to the machine shop soon as I can get it there, to see if it can be saved.
Good luck!
Old Nov 25, 2010 | 05:33 AM
teedeej340's Avatar
thanks for all the pointers
huntinco
Aug 28, 2011 08:40 PM
scotts74birds
Nov 19, 2009 01:49 PM
ProEmaster
Jun 6, 2007 11:31 AM
