stereo noise
stereo noise
I have a 1993 R/T10 Viper
I took out the two factory amps.
and put in one big 4 channel amp, I used the hot and ground from the old amps to this new amp
It works good except when the engine is running it has engine noise
I bought and installed a noise suppresser and it did not help.
Does anyone have any idea of what I can do to take care of this?
Thanks
Thanks
on
Did you remove any resistors? Radio, CD or both?
I know that I have them on my distributor and was told they're to reduce resistance you can hear or disrupt stereo.
first I took out the factory radio
and kept the stock amps
it all worked good with no engine noise
then I replaced the two amps with this one bigger one, that is when the engine noise started
Thanks
Thanks
Zeus77
11-12-2007 06:50 AM
