stereo noise
Old Oct 17, 2011 | 09:08 AM
rickyr's Avatar
stereo noise
I have a 1993 R/T10 Viper
I took out the two factory amps.
and put in one big 4 channel amp, I used the hot and ground from the old amps to this new amp
It works good except when the engine is running it has engine noise
I bought and installed a noise suppresser and it did not help.
Does anyone have any idea of what I can do to take care of this?
Thanks
Old Oct 17, 2011 | 10:09 AM
Commando's Avatar
Did you remove any resistors? Radio, CD or both?
I know that I have them on my distributor and was told they're to reduce resistance you can hear or disrupt stereo.
Old Oct 17, 2011 | 10:21 AM
rickyr's Avatar
first I took out the factory radio
and kept the stock amps
it all worked good with no engine noise
then I replaced the two amps with this one bigger one, that is when the engine noise started
Thanks
Old Oct 17, 2011 | 11:29 AM
78doubleR's Avatar
where does your ground go?
Old Oct 17, 2011 | 12:04 PM
rickyr's Avatar
It is the stock ground lead from the car that went to the stock amp
I am going to unhook it and run a heavy groung right to the frame
and see what that does
Thanks
64polara
Jun 18, 2010 06:51 AM
dealrocker
Feb 2, 2010 07:19 AM
shizane2002
Mar 25, 2009 05:01 PM
puffbunny
Mar 14, 2008 05:28 PM
Zeus77
Nov 12, 2007 06:50 AM
