temperature sensor
Old Jan 11, 2014 | 06:08 AM
Abnormal's Avatar
temperature sensor
I was wondering witch one of these ports I can put my mechanical gauge into.
The one on the right goes to the carb and a silver thing that looks like the vacum advance but is hooked straigt to the manifold.
The one on the left goes to to many t's and checkvalves to try to follow and this canister.
Thanks for the help guys. I looked for the actual sensor but could not find it but if somebody knows were its at would be great also.
Old Jan 11, 2014 | 08:25 AM
Mr.4spd's Avatar
You're hooking a temperature sensor up to vacuum lines? Or you're trying to find the temperature of the fuel? Most temp sensors are for coolant, transmission fluid, or oil. What are we trying to monitor here?
Old Jan 11, 2014 | 09:21 AM
I would just use the OEM spot for the sender and leave the OEM unhooked..
Leave all the vacuum ports sensors there... Now if you dont have to pass an emissions test. then you can delete it all and use one of the ports.
Just my 2 cents.
Old Jan 11, 2014 | 02:46 PM
Abnormal's Avatar
I can find the one that goes to my gauge I have looked all over. But saw that both those go into the manifold right by the thermostat and emissions is no worry for me.
Old Jan 11, 2014 | 03:08 PM
OEM Temp Sender is in the same area, Just on the other side of the engine. (Passenger).
Ok....Now that you looked.... The gauge you bought wont fit the small hole? Rite!
Old Jan 12, 2014 | 06:22 PM
Abnormal's Avatar
I have no spot on the other side of my manifold there is nothing there those are the only two spots on my manifold. If it is there I cant find it. But I was able to use one of those spots and it worked.
MilesP
Jul 5, 2013 09:19 PM
koondawg_74 roadrunner
Sep 21, 2009 07:51 PM
staledog
May 19, 2009 08:29 PM
JLanzino
May 11, 2009 04:00 PM
sgp7679
May 10, 2009 03:30 AM
