trouble code P 0420
Old Jul 6, 2010 | 09:33 PM
grabbergreendart's Avatar
Junior Member
trouble code P 0420
Upstream catalytic converter efficiency below threshold.
any ideas on how to fix?
Old Jul 7, 2010 | 03:44 AM
Replace the cat..... wait... did you say upstream cat?
Old Jul 7, 2010 | 07:26 AM
sweeperking's Avatar
This is for that 03 neon right?
Old Jul 7, 2010 | 06:32 PM
Junior Member
ya its an 03 dodge neon SE 2.0 manual.
Old Jul 7, 2010 | 07:56 PM
scotts74birds's Avatar
Isnt that kind of a generic code? Basically A/F mixture out of whack? As the O2 sensor reads it. Lots of causes.
Old Jul 8, 2010 | 04:01 AM
Just by researching the code and not looking at the car, its either the upstream (before the cat..) O2 sensor or a bad cat converter. Did you replace the down stream O2 sensor recently?
Old Jul 9, 2010 | 05:48 PM
Read this before you start throwing parts at it.
http://www.aa1car.com/library/p0420_dtc.htm
Old Jul 10, 2010 | 02:41 PM
Junior Member
well i replaced the sensor and also plugs. no more 0420 code. and now getting better idling and performance.
Old Oct 10, 2011 | 10:41 PM
ddunk80's Avatar
Code P0420 means "Catalyst System Efficency Below Threshold (Bank 1)"P0420 is actually Catalyst System Efficiency Below ThresholdCatalyst System Efficiency Below Threshold.
This means that the secondary O2 sensor detects that the catalytic converter isn't working as efficiently as it should.
This engine code can be triggered by any one of the following:
1.) The catalyst in the catalytic converter is cracked, clogged, or otherwise damaged.
2.) The secondary O2 sensor is malfunctioning.
3.) There is an exhaust leak.
4.) The computer unit is faulty.
jaygr
Oct 24, 2012 02:39 AM
grabbergreendart
Jul 6, 2010 10:18 PM
71RR08
Aug 14, 2008 07:36 PM
1972newport_sportsman
Jan 27, 2008 02:04 PM
slow70duster
Jun 29, 2007 02:55 PM
