Valve Cover Sealing Problems
Old Jun 10, 2009 | 03:01 AM
Polaradude's Avatar
Run a small bead of RTV around the gasket and bolt er up.
Old Jun 10, 2009 | 11:07 AM
scotts74birds's Avatar
You said you used rubber gaskets? Never had luck with those. Cork/rubber is the way I've always gone and had few problems. Torque on the hold downs should only be about 12ftlbs. Small bead if sealant if you want, but I just used hi-tack to hold the gasket in place and get good results.
Old Jun 10, 2009 | 11:40 PM
BuckNeccid's Avatar
There used to be some load spreaders, almost a diamond shape with a hole in the middle to help the bolt head spread the pressure onto a larger area of the head sealing surface. That may help. Me, I've always liked heavy cast valve covers, almost never get a leak.
Old Jun 12, 2009 | 03:52 AM
If you are using just the bolts, it won't seal properly. Those longer washers help out quiet a bit (or at least from my experience with them).
Second, when it come to valve covers and oil pans, I too have never had any good luck with rubber gaskets. As soon as I installed a set of cork gaskets with a little bit of Indian Head glue (I think thats what it is) I never had a problem. Put some of that on both sides, use a set of those washers with studs coming out of the heads and you should be golden.
Old Jun 12, 2009 | 06:21 PM
i use rubber gaskets
i install them, drive the car, then re-tighten the bolts
i've never had a problem by doing this
xvodysseusvx
Jun 25, 2018 04:38 PM
moparfreak66
Jun 30, 2013 08:41 PM
auerdoan
Jun 11, 2011 05:55 PM
jar84203
Mar 30, 2010 08:17 PM
sgnrulz
Jan 13, 2010 09:03 AM
