Valve train noise on a 318
Old Nov 5, 2010 | 06:55 PM
Mopar_Fan's Avatar
I just purchased a running 318 from a guy who has a 68 plymouth satellite.
It sounds great, and i got the whole engine with accessories and tranny for $300. The only thing bad with it is that it the valve train makes too much noise. I believe it is valve chatter and i want to know how i could fix. one of the valves also has some play with it, the engine also only has about 10 lbs of oil pressure at idle what could be the cause of that?
Old Nov 6, 2010 | 12:55 AM
1966sportfury's Avatar
A.K.A Bob Dodge
low oil pressure is usually bad bearing, or oil pump wore out clearances out of spec or wore spring in pump. you can raise the pressure my stacking the spring. but you mite as well go thru the engine. chattering could be wore cam rocker arms/shaft. lifters not pumping up, many things chances are you probly need to over haul it.
dkruk
Oct 17, 2013 10:29 PM
74Runneer
Dec 24, 2012 02:09 PM
combine450@yahoo.com
May 29, 2012 03:25 PM
PK1
16
Aug 10, 2011 07:03 PM
bschubarg
Apr 10, 2007 07:08 AM
