will a 400 big block work in a 63 chrysler 300?
Old Sep 13, 2011 | 09:43 PM
mr300's Avatar
i have a 400 big block out of a 73-76 dodge pickup and i was wondering if anyone knows if it will bolt in my 1963 chrysler 300 with no problems... the car originally had a 383 big block in it. thanks
Old Sep 14, 2011 | 12:40 AM
They are basically the same engine so You should have no problems
Old Sep 14, 2011 | 02:41 PM
mr300's Avatar
oh alright awesome thanks i appreciate it
Old Sep 14, 2011 | 06:56 PM
Should bolt right up EXCEPT I'm not sure of the balance issues between the two engines. I'm pretty sure a 400 is "externally balanced" so must have it's own balancer, but I'm not sure if the torque converter has balance weights on it, or not
Old Sep 14, 2011 | 07:31 PM
MercuryDon's Avatar
the Intake is not as wide on the 400 and the distributor shaft is shorter. If you get those with the 400 it should not be a problem. And yes the 400 is externally ballanced and I do believe the converter should be changed.
Old Sep 14, 2011 | 08:00 PM
John Van's Avatar
You might need to change oil pans,most cars have a center hump while trucks use a front hump. TVLynn is right they are about the same,the 400 has a larger bore with the same 3.75 stroke.
john,have fun take some pics and post!
Old Sep 14, 2011 | 11:07 PM
383 & 400 use the same intake and distributor size.. 413/440 is different
Old Sep 15, 2011 | 05:04 AM
62Furious's Avatar
The 383 is internaly balanced and the 400 is externaly balanced so keep the harmonic balance and the tork converter that comes with the 400, although B&M makes a flex plate that will let you use a internaly balanced converter on an externaly balanced motor
Gnar-kill
Oct 21, 2010 08:00 AM
minitruckin
Sep 16, 2010 09:09 AM
joel
Feb 22, 2009 06:58 PM
ntcongia
Jul 25, 2008 08:38 AM
