Windage Tray
Old 12-02-2008 | 08:50 PM
Commando's Avatar
Windage Tray
I have a question about something else I didn't see when I took the engine apart and that's a windage tray, is this important, should I get one? I know what it does and that supposed to prevent the oil from frothing. Also how do you put gaskets on with this, do you use 2 cork oil pan gaskets, and wouldn't this affect the dipstick reading?
For those of you wondering the first thing I couldn't find was the oil slinger, which I bought and plan on installing.
Old 12-03-2008 | 02:02 AM
rr69half6bbl's Avatar
the trays promary job is to kep the oil from splashing up onto the crank to slow it down beleive it or not it does. you use any pan gasket yu wan t1 on each side of the tray. then bolt it down. no It doesnt interferit will get an accurate reading
Old 12-03-2008 | 05:52 AM
Commando's Avatar
Oh ok, I didn't know that, I always thought it had to do with the consistency of the oil and all.
Old 12-03-2008 | 02:45 PM
ya
all it does is stop oil from splashing onto the crank to slow it down
i have it on my 440, and its stock
your supposed to use two oil pan gaskets, one on each side of the tray, and bolt, then torque the pan together.
i did this over the summer during my rebuild
Old 12-03-2008 | 03:06 PM
Commando's Avatar
Ok cool, I will look into getting one.
Old 12-03-2008 | 06:41 PM
great
where are you gonna look?
i would look on summit, they seem to have a lot of parts for a 440
Old 12-06-2008 | 09:39 PM
challenger's Avatar
you will get both gaskets if you order it from like summit or your parts store but check on the parts store and make sure it comes with two of them i do know summit gives you both gaskets in there kits
Old 12-06-2008 | 09:55 PM
i ordered a whole gasket set from summit, but it would only come with the one oil pan gasket, so i had to order another one seperatly, then they sent everything
Old 12-06-2008 | 09:58 PM
challenger's Avatar
67 did you order the tray also as when i got mine a year or so ago it came with both gaskets hehehe
Old 12-06-2008 | 10:01 PM
nope, i already had the windage tray on my 440
the hp 440 had some wierd things stock on it, like the windage tray and double roller timing chains
Old 12-07-2008 | 06:11 AM
Commando's Avatar
My friend has them in stock, hes got a couple thousand fel pros in stock.
I know I asked about the windage tray, but what prevents the oil slinger from moving around and scraping the timing cover?
Old 12-07-2008 | 08:32 AM
the oil slinger sits loose there, it isnt tight
but, it is bent in a way so it doesnt touch the timing cover
are you gonna put a double roller timing chain on your 440?
Old 12-07-2008 | 03:27 PM
Commando's Avatar
Yes, the one I got from edelbrock is. The diagram I saw shows the "point" of the cone shape towards the engine is that correct?
Old 12-07-2008 | 08:07 PM
do you mean the "cone" on the oil slinger?
mine was basically flat, except bent out away from the timing chain, but it fits into the timing cover, so it wont hit it
Old 12-07-2008 | 08:42 PM
Commando's Avatar
That's what I meant, it looked like it might move around a bit though.
Old 12-08-2008 | 02:12 PM
the oil slinger is supposed to have freeplay
all it is, is a baffle to stop oil from leaking out, and it helps protect the seal.
olibass1
07-26-2012 04:28 PM
Joe's challenger
01-12-2012 09:00 PM
76NY440_nTX
02-12-2011 01:33 AM
69POLARA383
02-11-2011 06:16 PM
