Windage Tray
Old Dec 2, 2008 | 07:50 PM
Commando's Avatar
Windage Tray
I have a question about something else I didn't see when I took the engine apart and that's a windage tray, is this important, should I get one? I know what it does and that supposed to prevent the oil from frothing. Also how do you put gaskets on with this, do you use 2 cork oil pan gaskets, and wouldn't this affect the dipstick reading?
For those of you wondering the first thing I couldn't find was the oil slinger, which I bought and plan on installing.
Old Dec 3, 2008 | 01:02 AM
rr69half6bbl's Avatar
the trays promary job is to kep the oil from splashing up onto the crank to slow it down beleive it or not it does. you use any pan gasket yu wan t1 on each side of the tray. then bolt it down. no It doesnt interferit will get an accurate reading
Old Dec 3, 2008 | 04:52 AM
Commando's Avatar
Oh ok, I didn't know that, I always thought it had to do with the consistency of the oil and all.
Old Dec 3, 2008 | 01:45 PM
ya
all it does is stop oil from splashing onto the crank to slow it down
i have it on my 440, and its stock
your supposed to use two oil pan gaskets, one on each side of the tray, and bolt, then torque the pan together.
i did this over the summer during my rebuild
Old Dec 3, 2008 | 02:06 PM
Commando's Avatar
Ok cool, I will look into getting one.
Old Dec 3, 2008 | 05:41 PM
great
where are you gonna look?
i would look on summit, they seem to have a lot of parts for a 440
Old Dec 6, 2008 | 08:39 PM
challenger's Avatar
you will get both gaskets if you order it from like summit or your parts store but check on the parts store and make sure it comes with two of them i do know summit gives you both gaskets in there kits
Old Dec 6, 2008 | 08:55 PM
i ordered a whole gasket set from summit, but it would only come with the one oil pan gasket, so i had to order another one seperatly, then they sent everything
Old Dec 6, 2008 | 08:58 PM
challenger's Avatar
67 did you order the tray also as when i got mine a year or so ago it came with both gaskets hehehe
Old Dec 6, 2008 | 09:01 PM
nope, i already had the windage tray on my 440
the hp 440 had some wierd things stock on it, like the windage tray and double roller timing chains
Old Dec 7, 2008 | 05:11 AM
Commando's Avatar
My friend has them in stock, hes got a couple thousand fel pros in stock.
I know I asked about the windage tray, but what prevents the oil slinger from moving around and scraping the timing cover?
Old Dec 7, 2008 | 07:32 AM
the oil slinger sits loose there, it isnt tight
but, it is bent in a way so it doesnt touch the timing cover
are you gonna put a double roller timing chain on your 440?
Old Dec 7, 2008 | 02:27 PM
Commando's Avatar
Yes, the one I got from edelbrock is. The diagram I saw shows the "point" of the cone shape towards the engine is that correct?
Old Dec 7, 2008 | 07:07 PM
do you mean the "cone" on the oil slinger?
mine was basically flat, except bent out away from the timing chain, but it fits into the timing cover, so it wont hit it
Old Dec 7, 2008 | 07:42 PM
Commando's Avatar
That's what I meant, it looked like it might move around a bit though.
Old Dec 8, 2008 | 01:12 PM
the oil slinger is supposed to have freeplay
all it is, is a baffle to stop oil from leaking out, and it helps protect the seal.
olibass1
Jul 26, 2012 03:28 PM
Joe's challenger
Jan 12, 2012 08:00 PM
76NY440_nTX
Feb 12, 2011 12:33 AM
69POLARA383
Feb 11, 2011 05:16 PM
