Wrong vibrations
Old Nov 17, 2010 | 04:52 PM
Chris Handy's Avatar
Wrong vibrations
Have 69 Dart 4 speed ! Just bought it ! Has 2" narrowed rearend. Had to make up new driveshaft. [had b body 4 speed] . Professonly made, balanced, I had it made up maybe a little short...2" out of tailshft. Any way I got bad vibrations 45 mph and up. Ideas ???????
Old Nov 17, 2010 | 07:42 PM
Archer's Avatar
Chris -
Welome aboard.
A perfectly balanced drive shaft that's 2" too short can give subtle or not so subtle vibration, usually when decelerating. Don't ask me how I know ...
The fact that you're getting it at a specific speed or rpm still suggests that the drive shaft may not be balanced as well as you think or one or more of your wheels/tires hasn't been balanced. The U-joints may also have to be looked at for alignment.
Old Nov 17, 2010 | 09:09 PM
Silverick's Avatar
I don't have the answer for you but, welcome!
Old Nov 17, 2010 | 09:30 PM
1966sportfury's Avatar
A.K.A Bob Dodge
welcome..
i my self never had a problem with the u joints not being aligned
i have seen professionally balanced driveshafts not be balanced correctly.
also tires being out off balance. if you have adjustable axles and they don't have the play needed (to tight) that can cause a vibration also.
Old Nov 19, 2010 | 03:28 PM
67Polara's Avatar
also dont have an answer, but welcome. and thanks for teaching a drive shaft can be out of balance. learn somthing new every day
Old Nov 20, 2010 | 03:33 PM
Thanks ! I'll double check it ! Chris
Old Nov 21, 2010 | 01:53 AM
toad490's Avatar
You can check driveshaft balance yourself, now I'm doing this from memory and at 56 that can be iffy. First get yourself a couple of hose clamps that will go around your driveshaft. Take one and put it on the shaft, TIGHT (mark shaft in quarters). Take the car for a spin, if the vib is worse move the clamp 180 degrees, take car for a spin again if it's worse still move clamp back and add other clamp in the same position, take car for spin and see if it's better. In short move one or two clamps around and see it you have any improvement, if not the problem is elsewere.
BTW, I went thru this with my Cuda after I bought it only to find that there was no nuts on the tranny mount!!
demetri
Mar 28, 2016 02:29 PM
beuvyler
Pro-Stock
Jan 11, 2009 05:33 AM
beuvyler
Oct 6, 2008 02:43 PM
azzkikr
Mar 3, 2008 08:45 PM
rampage_82
Dec 7, 2007 08:22 AM
