Tech Talk of the Month In this forum, we will be talking about different technical aspects of the world of Mopar. From motors to suspensions to body work. One of the Mods will start all thread in this section.
TTOTM - Big block swaps
Old Aug 3, 2010 | 05:48 PM
I know I'm a few days behind but lets hear what is out there for swapping in big block motors into cars/trucks. Doesn't matter what was in there before, slant 6, SB, another BB, a birds nest, doesn't matter.
Old Aug 8, 2010 | 03:47 AM
Nobody has any info they would like to share?
Well I have swapped out a slant 6 for a 383/727 BB combo in an 85 D100 and I can tell you this; the crossmember can be used with the stock rubber mount, the motor will drop right in between the frame rails (you just need the proper mounts), and you should upgrade the front coils to a set from a 1 ton. As for the radiator, just get a 3 or 4 core and be done with it.
As far as it goes with swapping a BB into a car, I do know that you will need torsion bars for a BB car as they are different than that of the SB cars.
Old Aug 8, 2010 | 09:41 AM
blue 68 gts's Avatar
My Dad came up with the idea and we had it done to both of our K-frames.
Notched out a good chunk of metal and squared it off to make engine removal/installation alot easier then trying to fight against the fire wall and K-frame.
first pic is mine in the car, 2nd pic is his. They were done by seperate people. Mine was done for free and he had to pay for his... Got to love Mopar guys who will help a kid out. He drove an hour out to drop it off at my house!
His got painted too, thats right when he brought it home.
Old Aug 9, 2010 | 11:53 AM
2002ram440's Avatar
I am the odd ball on this site with a Ram but I swapped out a 4.7L v8 and put a 440 with a 727 tranny. None of the factory brackets worked with the 440, everythign had to be made. The truck was 2wd but i put a staright axle in the front and a seperate transfer case. I took my love for trucks and my desire for a muscle car and created my own low budget muscle truck.
Old Aug 9, 2010 | 12:47 PM
Thumbs up
Nice job 2002ram440!
Nick,
I like that K-member fab.
Old Aug 9, 2010 | 01:18 PM
1966sportfury's Avatar
A.K.A Bob Dodge
my dad and i swapped out a 6 cyl in a favor of a 440, in a 67 cuda, the owner wanted to retain power steering so we had to move the engine to the left 1 inch for clearance, (big block cudas in 67 didnt come with power steering)
my fury bless its sole, was factory 318 A, then i put a 440 rb in it,
just about every car we had that came with a small block or a 6 got a BB, except for the diplomats or lebarons
Old Aug 9, 2010 | 03:38 PM
What mounts did you use? Did you guys change out radiators? What did and did not clear?
Old Aug 9, 2010 | 03:44 PM
if you have a sb k-frame, schumacher is probably the way to go to get a bb in it?
their mounts will allow you to keep the sb k-frame.
the sb k-frame is strong enough to support the motor, but the suspension might not.
when doing a big block swap, also keep suspension in mind. torsion bars might have to be changed in order to support the motor
Old Aug 11, 2010 | 11:25 AM
I have stock suspension. New shocks front and rear, original leaf springs that left with the car 42 years ago, with 1 leaf added to each side.
I have 318 torsion bars, 42 year old original ones for my car.
My dad as slant 6 torsion bars
Old Aug 11, 2010 | 06:22 PM
A.K.A Bob Dodge
we made our own mounts off of the k frame cut the old ones out, we used a 3 core BB radiator,
since the guy wanted power steering in the car the pump wouldnt clear, so instead of chopping the car we just moved the engine over,
it still has stock suspension in it as far as i know? we did that probly 12 yrs ago and he sold it about 6 yrs ago, the BB did lower the front end about an inch or so, my dad had to make a oil pan to fit, then the guy took my dad for a ride (they are friends) my dad said mike went down an alley way at about 80 and there was a rock sticking up about 4" and took the bottom of the oil pan off,
Old Aug 13, 2010 | 08:20 AM
isn't your dad's car a drag car though?
i was referring to using the car around town; handling.
Old Aug 13, 2010 | 08:34 AM
A.K.A Bob Dodge
drag car would need better components than a street drivin car,
i dont see a problem with what his dad is running,
Old Aug 14, 2010 | 07:54 AM
is his dad running a sway bar?
i am not knocking anyone
i am just saying that when you put in a bigger motor, there are other things to consider rather than just how fast you go
Old Aug 14, 2010 | 09:32 AM
A.K.A Bob Dodge
i am not knocking anyone, there are other things to consider rather than just how fast you go
very true not just how fast you go, how long does it take to get to 160
Old Aug 14, 2010 | 01:14 PM
Neither of us run sway bars. His car isn't a full out drag car. It has a roll bar, it has race seats. But he drives it on the street quite a bit.
My car is a pure street car that "just happens" to run 11s.
The slant 6 torsion bars help for a better launch
Matt, I drive my car all over the place. Around town, on the freeway, ect. I can't take a corner at 50 mph like a new car can. But my car handles very well, especially when I feel like breaking the tires loose.
Old Aug 14, 2010 | 01:27 PM
Matt, I drive my car all over the place. Around town, on the freeway, ect. I can't take a corner at 50 miles per hour like a new car can. But my car handles very well, especially when I feel like breaking the tires loose.
I wonder how much better the cornering would be if you installed BB torsion bars and then how much better, on top of that, it would be with a sway bar hooked up, or even with just the sway bar hooked up with the torsion bars that you are running now.
Old Aug 14, 2010 | 02:33 PM
That'll hinder my performance at the track. The best way for a good launch is slant 6 bars and no sway bar.
If i was daily driver-ing my car, I'd put different bars on and a sway bar.
Looking at buying a 69 GT that'll get a small block, that'll get a sway bar.
Old Aug 15, 2010 | 10:58 AM
why is that?
Old Aug 15, 2010 | 01:03 PM
why is that?
They are a smaller diamater and allow the front to lift up more
Old Aug 16, 2010 | 02:36 AM
We can get into torsion bars and setups more when the TTOTM is suspensions (comming soon )
Old Aug 16, 2010 | 02:41 AM
Too add to my second post - I know when swapping out a /6/V6/sb V8 out of a truck (post 72), that most of the frames were set up to take BB motors all they way up to 93. I believe that they stopped putting BB motors in to the trucks in 78 but with the stock BB motor mounts and brackets, you can drop them right in with no issues. You just need to make sure that you have a rear sump pan and pick-up.
Old Sep 29, 2012 | 09:11 AM
Chryco Psycho's Avatar
Too many variables but for most 60s up to 72 any V8 will bolt into any V8 K except the Hemi all you need is mounts , Schumaker does have a mount for hemi into V8 & V8 into slant 6 as well . In 73 with the change to spool mounts things change , the Big block v8 K is different from the small block & you need special mounts to put a big block into an A body . oddly the E body retained the sandwich mount through to the end in 74 .
the Trucks are similar , you can bolt a big block in with factory mounts into the late 80s , the dakota Magnum engines have the mount in a different position on the side of the block & do not bolt into full size trucks .... guess how I found this out !!
As for all the new 3rd gen Hemi swaps I am still learning .
Old Dec 1, 2012 | 04:50 PM
Demon72's Avatar
I want to put a 5.9 magnum v8 ( out of a 98 ram 1500) into my 68 coronet, any advice or tips?
Old Dec 1, 2012 | 05:00 PM
  #24
relatively easy swap , the 5.9 is balanced differently from a 360 LA so watch for that , otherwise it is a basic small block swap , Schumaker will have a mount kit , What trans are you using? are you going to try to run the EFI or switch to carb ?
27
Jul 7, 2013 04:47 PM
Mopar_71
35
May 20, 2013 09:57 PM
drpreposterous
Feb 8, 2012 09:53 PM
Jul 11, 2010 10:37 AM
Jun 28, 2010 01:55 PM
