09 Hemi Headbolts
Old Nov 11, 2022 | 11:57 AM
Keefbikes's Avatar
Question 09 Hemi Headbolts
New here, would appreciate some insight from the more experienced.
I am replacing the cylinder head on my 09 Ram 2500 Hemi 5.7lt. I have read conflicting views on the use of oil on the head bolts. Some say that they do not go into any coolant jackets or oil pockets, so adding oil to a closed sleeve hole increases resistance and gives false torque readings. Is this true?
I have also ordered:
- FEL-PRO ES72200 head bolts
-FEL-PRO HS26423PT Head Gasket kit which includes intake, valve and all other gaskets needed-$129
Are these suitable or should I use only dealership 'em parts?
Need to order new thermostat, spark plugs, and I replaced the belt about three months ago so that should be fine.
Old Nov 11, 2022 | 12:43 PM
Drag Pak's Avatar
ARP Ultra Torque Fastener Assembly Lubricant
ARP head bolt kit
Old Nov 11, 2022 | 01:06 PM
Keefbikes's Avatar
Isn't ARP going to fall under the same principal, anything other than bolt and head will change the force needed?
Old Nov 12, 2022 | 09:58 AM
Do as the factory MFG recommends !!!! See what the service manual tells you.... It last a long time that way...
armeniansdoitbetter
Jul 7, 2015 11:35 AM
69POLARA383
42
Aug 15, 2012 01:49 PM
ohsplat
Feb 6, 2011 04:19 AM
tagster
Sep 9, 2010 01:04 PM
sgp7679
Jan 7, 2010 12:58 AM
