1.6 roller rockers B engine
Old Nov 2, 2025 | 02:59 PM
droptail's Avatar
I have new Speedmaster heads and my old Crane Cams 64790-1 T Gold Race Roller Rockers 1.5 are a little too short so I thought the 0.100" longer 1.6 rockers would work.
I need suggestions for good valued 1.6 roller rockers.
Im not sure about self aligning.
thanks
Old Nov 3, 2025 | 07:48 AM
Check the 440 Source..... Not sure if they fit the speedmaster heads... But if they do, that should help out the issue?
Old Nov 3, 2025 | 01:04 PM
[QUOTE=droptail;165133]I have new Speedmaster heads and my old Crane Cams 64790-1 T Gold Race Roller Rockers 1.5 are a little too short so I thought the 0.100" longer 1.6 rockers would work.
thanks[/
self aligning?
are you talking about using the springs separating the rockers?
Because you should be using tubing and shims to separate the rockers.
Old Nov 4, 2025 | 06:58 AM
[QUOTE=Iowan;165136]
thanks[/
self aligning?
Kind of why i recommend the 440 Source.... they have a good guide on sett up the rockers and shafts....
Old Feb 26, 2026 | 02:12 AM
dkoxla's Avatar
One thing I didn't hear mentioned is that a roller tip can reduce side load on the valve stem. This has the potential to increase the service life of both, the valve and the guide. For those of us who want or need to build long lasting engines, that makes roller rockers an investment in durability, as well as reliability.
snaptube vidmate
Minidak
Apr 24, 2013 11:09 AM
rcknrolfender79
Mar 18, 2013 12:16 PM
Zoomer59
Mar 8, 2013 08:46 AM
douglas340
Apr 14, 2011 03:59 AM
fury413rb
Apr 17, 2007 08:22 PM
