1966 Valaint with A-727-RG automatic transmisson what engines bolt up?
Old Feb 13, 2013 | 03:05 PM
Thecollector's Avatar
Question 1966 Valaint with A-727-RG automatic transmisson what engines bolt up?
I have a 1966 Plymouth Valiant 200 with some research I found out that it might be a A-727-RG 3 speed torque flight automatic transmission.
I currently have a 255 slant six bolted to it, However It might unfortunately be junk(Not sure still trying to get it going properly) If it does end up being junk I would rather just drop another engine in i think it would be the cheapest and quickest way to go.
I can locate 318s almost everywhere would one bolt up to the transmission I have I am sure i would need the bell housing. with my truck I am able to run any engine made those years with the same transmission I'm curios to see if that is the same for this transmission.
any other engines you know would bolt up please let me know thank you very much! it is tough to find any information on something this old for some reason.
Old Feb 13, 2013 | 03:55 PM
NO the 6cyl trans is specific to the 6 Cyl engine. Most likely you have a 904 trans, not a 727. IF you do have a 727 it is a very rare to find in a car mostly used in trucks
Old Feb 13, 2013 | 04:48 PM
thank you for the information Its much appreciated.
So if i do end up going that route I would need a transmission as well as an engine.
Old Feb 13, 2013 | 10:04 PM
A lot of people do it.. It takes some work Quick list you need motor and trans of course. also motor mounts, radiator, exhaust, drive shaft, rear end, upgrade to disk brakes .... ? depending on what is in the car now
Is it a 3 speed auto 727 is an auto or
3 speed standard ????
Old Feb 14, 2013 | 05:12 AM
yep I thought as much for the parts list, the front end just has the oem breaks, I plan on upgrading the breaks to disk up front and for sure ditch the suicide master cylinder. if i do go the engine swap route I really hope to find a 440 or a 426 hemi just because a hot rod wagon would be very epic. I would settle for a built 318 as well.
the transmisson is a 3 speed automatic transmission.
Old Feb 14, 2013 | 02:13 PM
The 66 A body has a smaller engine bay than the 67 up 440 or Hemi requires major surgery. A good 400" small block stroker would be more than up to the job
Old Feb 14, 2013 | 10:31 PM
that is good to know, still would be a very intresting wagon with a 440 in it haha
Im sure this is blasphemy but I do have a built 350 and transmission I could put in, but lucky for me it seems that its just a timing issue with the 225 slant six. never know down the road I might want to put in a higher hp engine. for now the 225 should to the trick just moving it around the yard
Tom T2
Aug 23, 2015 07:21 PM
pro-tech
Mar 30, 2014 07:46 AM
bigred
Sep 23, 2013 04:08 PM
willysman69
Feb 26, 2012 06:33 PM
sgp7679
Mar 9, 2009 07:42 AM
