1970 Tucker Snow Cat
Old Sep 19, 2019 | 02:06 PM
Snowmosteve's Avatar
So I’m really new to mopar engines, so please forgive my ignorance. I have a 1970 tucker snowcat with a 318 industrial engine. I recently replaced the old tired engine with a newer 318 block with rv cam. Purchased from a local engine builder. I put it all back together and fired it up, however found water in the oil I immediately thought it was a cracked head. I also found coolant in the #1 cylinder. I pressure tested the number one cylinder and it tested fine. I’m now thinking it my be the intake manifold. Does any body know if the industrial motor has a different intake that maybe doesn’t fit correctly? It did look ok, but like I said I’m definitely new to mopars. Please chime in as to where you think the coolant could be leaking from.
Old Sep 20, 2019 | 10:08 AM
Compression was good when you checked it ?
What happened when you pressured checked the cooling system and left the number one spark plug out? Did water run out?
trenk
Oct 2, 2019 08:53 PM
D4Dartswinger
Oct 20, 2017 10:14 PM
TypeO
Aug 29, 2014 08:21 AM
Chris.
Aug 18, 2014 01:16 PM
flathead31coupe
Jul 7, 2010 07:51 PM
