1972 charger shuts off
Old Jul 14, 2022 | 05:41 PM
Marilij7837's Avatar
Hello,
I recently purchased a 1972 charger with a 360. The car was shutting off at reverse quickly or on drive when accelerated too hard.
I changed the fuel pump, plugs, wire, fuel filter, alternator, battery.
after changing the fuel pump it stays on when hitting gas, but now shuts off when it warms up. Then to turn on it doesn't hace spark.
I have checked the carburetor, and also for any vacuum leaks.
will be changing coil tommorow, but any idea what it might be?
Old Jul 15, 2022 | 01:46 AM
Archer's Avatar
M -
Hard to say without seeing it.
Does the engine sound like it's running out of gas or is it immediate?
Can you tell how much fuel is in the carburetor fuel bowls/float levels, assuming a Holley type carb?
No spark means electrical, and unless you can see burnt wires/relays, it may just be a replace one thing at a time thing.
(Assume you have an electronic ignition/ECU?)
Old Jul 15, 2022 | 07:34 AM
Why did we not change the Cap. Rotor, Points and Condenser, and the Ignition Coil, ????
I'm guessing with all that you have done that it has a weak Ignition coil or a condenser that is acting up... Some of this also sounds like the carburetor may need a good going threw.
Old Jul 16, 2022 | 09:37 AM
@RacerHog
I just changed the items mentioned, once the car warms up and i have it on drive it looses power and tries to shut off
Old Jul 16, 2022 | 12:10 PM
Do you know if your loosing the 12Volt referance coming out of the ignition switch?
OhMrFister
Oct 1, 2018 11:18 AM
Detroit high Octane
Jun 2, 2018 08:25 PM
Ryngus
Aug 8, 2017 05:24 PM
justun
Mar 6, 2016 03:19 PM
jeff1010
Aug 8, 2011 05:42 PM
