1984 360ci no power under load
Old 11-05-2021 | 02:04 PM
angelz's Avatar
I have a 1984 power ram w350 with a 360 ci that bucks when under load " no power". Idles great I've replaced the ignition system distributor, coil, icm, fuel pump and filter all to no avail. Please help.
Old 11-05-2021 | 06:48 PM
I'd look at timing then fuel, check total timing and when that happens then make sure you have fuel. Make sure fuel pump is up to snuff and filters are clean then look a carb...
Old 11-06-2021 | 09:07 AM
Also I will add.... Check the exhaust to see if it is restricted?
Iowan (11-06-2021)
87slant6
12-14-2019 12:26 PM
Lana
08-14-2012 09:45 AM
67Polara
11-19-2010 04:53 PM
myersjsm
06-07-2010 03:09 PM
BlueSmoothie
08-22-2009 11:55 PM
Quick Reply: 1984 360ci no power under load
