1984 360ci no power under load
Old Nov 5, 2021 | 02:04 PM
angelz's Avatar
I have a 1984 power ram w350 with a 360 ci that bucks when under load " no power". Idles great I've replaced the ignition system distributor, coil, icm, fuel pump and filter all to no avail. Please help.
Old Nov 5, 2021 | 06:48 PM
I'd look at timing then fuel, check total timing and when that happens then make sure you have fuel. Make sure fuel pump is up to snuff and filters are clean then look a carb...
Old Nov 6, 2021 | 09:07 AM
Also I will add.... Check the exhaust to see if it is restricted?
87slant6
Dec 14, 2019 12:26 PM
Lana
Aug 14, 2012 09:45 AM
67Polara
Nov 19, 2010 04:53 PM
myersjsm
Jun 7, 2010 03:09 PM
BlueSmoothie
Aug 22, 2009 11:55 PM
