1984 dodge rampage 2.2l. where can i find a turbo?
Old Jun 4, 2012 | 08:08 PM
RobinHoodRampage's Avatar
i just bought the rampage. runs good already only has 50k miles. but im going to paint and sand it down in the next month including the engine bay. so im gonna pull the motor. im 19. so i want to turbo it.... hahaha anyone know where i can find one? a site or store or anything... thanks everybody!!!! my first restoration project and im going big =DD
Old Jun 5, 2012 | 02:19 AM
I'd find a Shadow that is turbo and swap that all in. Another way is to find a turbo that is the right size for that size motor and then fab it in. You're looking at a lot more $$$$$ this way as there is a lot of customizing, not only to the intake, exhaust, intercooler (if you want) but to the wiring and software for the fuel injection.
Check out turbododge.com and see what they say. I'm sure that people over there will give yous ome good input.
Depending on how much you are looking to spend, you could always look into turning the front wheel drive "truck" to a rear wheel drive monster with a Magnum 360/46RH setup.
Old Jun 5, 2012 | 04:03 AM
PK1's Avatar
PK1
x2
A turbo from 84 will need a rebuild but its the tubing, fittings, brackets, fuel regulator, etc.. that you need. Get a wrecked one to steal from.
Other than saving a HUGE amount of money buying a wrecked donor car you would have an extra block, heads and trans ( find similar model). If this is your first project you can disassemble and rebuild while you do your other projects.
As a first project a "plug and play" type project will be easier than a fabrication style one.
envyedrico
Jun 19, 2010 11:03 AM
hey_joe42
Jan 22, 2010 12:41 PM
offroadohio
Feb 12, 2009 11:08 PM
offroadohio
Jan 28, 2009 05:55 PM
Danny
Dec 24, 2006 12:37 PM
