318 overheating
318 overheating
I know this has come up before, but maybe there are some new genius' on here that can help me from loosing so much hair so fast. I have a 69 charger with a 318 that won't stay cool. I have:
replaced the thermostat after checking it to make sure it opens at 180 degrees.
drilled a hole in the flange of the thermostat
Replaced the sensor in the block.
removed and cleaned out the radiator
but it still climbs to 270 (thats as high as the stock gauge goes) in about 10 minutes even on the highway. But when I stop its not puking coolent or steaming like I would imagine it would at 270. Could the gauge be bad? It just started doing this this month. The only thing I haven't done is get a shroud. Would a shroud make that much difference? Any help would be awesome. Thanks.
arron -
Basic rule, do the easiest thing first, even if it has a low yield.
Check the gauge first, just borrow or buy an cheap Sun gauge from Advance or any parts store and hook it up to a different port.
An IR thermometer isn't expensive (around $30) and can help finding hit spots and has a lot of other uses.
As far as the water pump goes the impellers rust and has nothing to do with the seal.
well its not the water pump. Just pulled it since I already had the fan off and radiator out. It 's fine. No bubbles in the coolant either. I checked before i pulled the rad to clean it. So I guess Ill put it all back together and see if its the temp gauge.
If it was a head gasket or cracked head wouldn't I get white "steam" from the exhaust and a noticeable loss of coolant? I have had a blown head gasket and a cracked head on another car and it poured white exhaust.
Well got it solved. It was a bad gauge. I installed a new temp gauge (in a different port so I could get both reading at the same time) and the stock gauge was pegged at 270 and the new one read 190 with a 180 degree thermostat. On the up side I now have a new thermostat, water pump gasket, temp sending unit, a clean radiator, a flushed engine and now know much more about my cooling system. All's well that ends well! Thanks for you input everyone! On to the next thing, Disk brake conversion.
Now you have it running properly take some infrared gun temps with engine running of the thermostat housing and rad hoses. Record the information to compare in the future if you have a suspected problem in the future.
53cranbrook
Jan 11, 2013 06:31 AM
