346 Heads
Old May 15, 2014 | 06:58 PM
mrzods13's Avatar
346 Heads
Just picked up a pair of 346 Heads, need to be redone but in great shape, no rust or damaged threads. Will these work ok on my chrysler 383 with an upgraded cam with a .480 lift: it's a comp cams 268H XE. Another question I have is should I use the edelbrock intake bolts with the performer rpm intake, just want to have the proper length bolts this time, thinking thats why the heads cracked where the intake bolts on. I am figuring it will cost around $600 for the heads to be redone and assembled.
Old May 15, 2014 | 07:21 PM
http://www.moparmusclemagazine.com/t...ylinder_heads/
Old May 15, 2014 | 08:55 PM
mrzods13's Avatar
I have read the article before. The 346 heads had higher numbers towards the .450 lift. But are the higher numbers good or bad still new so I am learning. Also I am positive the heads I have are not the flat head smoggers. The casting number has 346 at the end not 345 as they said in the article. The guy has HP 906 heads also which only has the stiffer springs. But I was thinking of going back and grabbing those too. Only $100 so and in decent shape.
Old May 16, 2014 | 06:20 AM
ether of those will work just fine with a daul plain manifold and that style cam...
Just dont hog them out....
Old May 16, 2014 | 08:09 AM
mrzods13's Avatar
Hog them out?
Old May 16, 2014 | 08:50 AM
Porting
Old May 16, 2014 | 08:52 AM
mrzods13's Avatar
Yea not gonna be doing that.
Old May 20, 2014 | 09:54 AM
mrzods13's Avatar
Well I took the heads off today, looks like they put flat top pistons in the block .30. Will the 346 heads still be ok with those.
mrzods13
May 21, 2014 03:07 PM
todd383
Jul 27, 2013 05:04 AM
getsum
Dec 10, 2009 10:01 AM
