360 hesitation
Old Sep 4, 2020 | 08:42 AM
Ashton1012's Avatar
360 hesitation
Hey everyone!
im working on my 1977 dodge RV and was hoping for some help. She has quite a bit of hesitation when I hit the gas, nearly dies especially when cold. When I punch the gas it does snaps out of it. She also doesn’t like idling in gear when cold.
ive replaced;
cap and rotor
spark plugs and wires
fluids all changed
air filter
pcv valve
rebreather
seafoam in the fuel tank
carb cleaner sprayed through the carb and vacuum lines going to the carb per the instructions
only thing left is to change the fuel filter, I accidentally got the wrong size.
I’ve never played with mopars before, I’ve always had fords! I read somewhere these 360s like to have the timing advanced a little? I appreciate any and all tips! Thanks everyone
Old Sep 4, 2020 | 10:43 AM
Yeah, but mopars also like to ping, haha. Timing is a fickle mistress with them. Sounds like the carb probably needs a rebuild on that beast.
Old Sep 4, 2020 | 04:41 PM
I agree sound like a carb overhaul is order... Needs a new Accelerator Pump and for the Choke to be adjusted... From what you are describing...
Old Sep 4, 2020 | 07:03 PM
Drag Pak's Avatar
It also probably wouldn't hurt to check that the advance mechanism is not seized?
Moparnut1970
May 24, 2020 07:47 AM
Moparnut1970
Sep 1, 2019 03:38 PM
BTYM
Mar 8, 2014 08:30 PM
Barfly
Jul 18, 2011 03:55 PM
Salty
Dec 17, 2010 12:33 PM
