360 SB mopar distributor for MSD wires
Old Mar 1, 2016 | 04:47 PM
josehf34's Avatar
I changed my new HEI type distributor for my old and tired stock mopar one and my 74 Fury now runs a lot better, but, this distributor has the vacuum advance broken, has never been rebuild and I want to use the MSD wires I bought for the HEI type distributor.
I checked on Rockauto but looks like the mopar distributors they sell only have female type cap and the MSD wired needs male type cap
What should I do? I want to run my MSD wires and a high voltage coil
I need this type of cap
Instead this type
Old Mar 1, 2016 | 07:35 PM
I've been useing MSD for over 25 years, so red or black? What was the question?
Old Mar 1, 2016 | 08:46 PM
josehf34's Avatar
Is there a way to use my HEI type MSD wires on a Mopar type distributor cap? or would be a better idea to change wires or distributor ?
Old Mar 2, 2016 | 07:36 AM
I'm not a fan of oem distributors for performance applications.
Old Mar 2, 2016 | 07:43 AM
DDodger's Avatar
Took about 30 seconds on Google. "440 source" shows one, I did not look any further
http://store.440source.com/Distributors/products/62/
Old Mar 6, 2016 | 05:05 PM
josehf34's Avatar
I'd suspect that cap is made for a big block dist, or the cap from a big block dist is the same of a small block?
Old Mar 7, 2016 | 06:55 AM
SPAMBURGER's Avatar
http://www.hughesengines.com/Index/products.php?browse=category&level0=QS0gU21hbGwgQm xvY2sgIkxBIg==&level1=SWduaXRpb24gJiBFbGVjdHJpY2Fs &level2=Q2FwcyAmIFJvdG9ycw==
Try this. They should have what you need.
Old Mar 7, 2016 | 09:52 AM
DDodger's Avatar
Big/ small block use same cap and rotor. Of course they must be same "series" ie the old Prestolite dual point use a different cap and rotor than do the single point aluminum and the electronic breakerless dist.
Old Mar 7, 2016 | 11:27 AM
Archer's Avatar
j -
I may be wrong about what you're asking, but most universal wire sets have both types of cap boots. Or you could just buy an after market set of boots and use them on your new cap.
68GTX440
Sep 21, 2013 01:10 PM
3rd1970RR
Oct 14, 2012 04:28 PM
Macjeep
Jun 19, 2012 12:01 PM
fmontez1
Jan 5, 2012 09:21 AM
wingnutt2420
Jan 8, 2011 10:23 AM
