4 barrel swap
Old Dec 24, 2013 | 12:09 PM
powerwag73's Avatar
4 barrel swap
I have a 73 power wagon with a 318 points distributor (which I hate) I want to put electronic ignition back in it. But I recently replaced the 2 barrel Carter with a 4 barrel edelbrock intake abs edelbrock 600 cfm carb. I got it to run with manually working the carb but I can't get the throttle linkage to line up. Any suggestions. Find a 4 barrel truck or car at the junk yard and get the bracket? I miss my truck and want it to be back on the road again. Thanks everyone and merryChristmas.
Old Dec 24, 2013 | 12:21 PM
Archer's Avatar
pw73 -
You could do that, but getting an aftermarket linkage like the one from Lokar might be easier. If there's a kick-down linkage as well, you can use two of the Lokars.
There simple conversion kits from Mopar and others including a distributor, control box, resistor and harness. One of the easier thing to do.
Old Dec 24, 2013 | 12:37 PM
Assuming you have an auto ? FIRST there is a mopar specific throttle arm adapter that you need for the carb and the 4 bbl linkage from the bell crank mount to the carb
http://www.summitracing.com/parts/edl-1481/overview/
Old Dec 24, 2013 | 03:19 PM
moe7404's Avatar
ill say it AGAIN. you need ALL the 4 bbl parts. not just carb and manifold. I.E. cable, bracket, throttle linkage, i hope iam not forgetting something. AND a STEEL fuel line. you wasn't thinking .of using hose for a fuel line WAS YOU? if you do you need to get a fire extinguisher.
Old Dec 24, 2013 | 08:08 PM
DodgeAddict's Avatar
I use a Bouchillion kickdown cable kit & throttle cable bracket
Using this takes away all the guess work & allows use of cruise control & is made by Mopar people & uses mostly Mopar parts & was not originally designed for a Chevy
Old Dec 25, 2013 | 02:49 PM
moe7404's Avatar
my o my. a 2 bbl to 4 bbl swap with a cable lined up rightly. wow o wow some of you cats DO know what your doing.
Old Dec 25, 2013 | 07:56 PM
Archer's Avatar
pw73 -
This is about as clean a set up, as you're going to get (IMHO anyway).
The Lokar bolts on to a carb bolt and is locked in place with screws.
Old Dec 25, 2013 | 08:10 PM
moe7404's Avatar
yea bolting to the carb is a very good idea. seeing as how organal O.E.M. parts are hard to come by.
Old Dec 26, 2013 | 09:38 PM
ZombiePopper's Avatar
Just my 2 cents here,
But I'd get your carb set up sorted out and THEN worry about your points dizzy,
There's nothing wrong with points and they work well for the majority of vehicles, as long as the gap is set correctly, no prob.
Run it until you get all your elec ign parts collected for the conversion.
Polara-Lee
Jun 18, 2020 09:41 AM
phish1270
Sep 23, 2009 04:25 AM
arizonamoparts
Jul 29, 2009 01:30 PM
ken g
May 17, 2009 06:16 AM
skymynx
Nov 12, 2008 09:55 AM
