41 plymouth timing
Old Oct 30, 2013 | 06:22 PM
duzenack's Avatar
41 plymouth timing
How do I set ignition timing on a 41 plymouth
Old Oct 30, 2013 | 09:37 PM
According to my old Motor's Manual, tune up specs as follows
Spark plugs, Autolite AL-7B @ .025" gap
breaker points .020" gap, 35--38 degrees dwell
Timing says "DC" or "0" mark on dampener
idle speed 475 RPM
A photo shows the pointer should be on the timing cover almost directly above the dampener.
And no.........I'm not quite THAT old!!! My Dad was, though!!
Old Oct 31, 2013 | 08:19 AM
Welcome To the Forum Duzenack.....
440roadrunner...is old..... But full of good Info...
Post up some pictures when you get a chance.....
Old Nov 1, 2013 | 09:20 AM
duzenack's Avatar
idle speed 475 RPM
Old Nov 1, 2013 | 09:23 AM
duzenack's Avatar
Thanks. Yes I am that old. I am older than this car by 1 year. My manual gives some information but it refers to #6 cylinder. Do I use #1 or #6. Can you tell me the firing order? Be thankful for Dads.
Thanks, Paul
Old Nov 1, 2013 | 09:54 AM
Firing order is 153624. All I could find in Motor's refers to no1. There are very few engines not timed off no1. IHC V8s are one, they use no8 which I've always thought was plain silly
Old Nov 2, 2013 | 06:50 PM
duzenack's Avatar
firing order
Thanks again for the help. I am getting the engine put back together. Hope it runs.
\Paul
19newport72
Mar 27, 2024 06:44 PM
furysrule
Apr 29, 2015 07:13 PM
Kyle Monroe
Mar 8, 2014 06:40 PM
Gorts 5th
Dec 19, 2012 04:52 PM
a.johansson84
May 27, 2012 03:30 AM
