426 to 440 interchange
Old Jan 28, 2014 | 05:44 AM
straw43's Avatar
New to site and posted in wrong area...Hello. I have a 65 polara with a 426 street wedge. I have new pistons, cam. I suspect the remainder of parts are 440 interchangeable but unable to confirm. ,I am wondering if cam bearings, freeze plugs, oil pump, gaskets, rocker arms, push rods ect will be the same for 426SW and 440. Anyone know? Thanks for the answers so far!
Old Apr 27, 2014 | 09:44 AM
harv65's Avatar
I have a similar question I want to know if you could put the 426 hemi heads on a 440
Old Apr 27, 2014 | 12:40 PM
moe7404's Avatar
if i remember right. in 65 the "B" "RB" engine had a strange mount bracket on the left side. i had to make custom bracket to put a 440 in to a 65 chrysler frame. i made a bracket to bolt into the boss next to the oil pump. and go up to the mount. man that was a LONG time ago. i think the 426 wedge has different mounting than a 426 hemi.
Old Apr 27, 2014 | 01:10 PM
Absolutely NOT. This rumor seems to persist. The 426 hemi is "similar" to the wedge engines and is pretty much "based on" the design, but that's about it.
Old Apr 27, 2014 | 01:31 PM
moe7404's Avatar
years ago i saw wher guy ground on the 440 block and welded a spacer / plug to duplicate the 426 hemi casting to bolt the stud coming off the hemi head. seemed to work. but that was in days whey didnt have the very good 440 heads we have now. but not sure any other differances.
Old Apr 27, 2014 | 03:56 PM
Your six items listed should be good, I would check cam bearing journals and main crank thrust face register, just to be sure.
Here is some stuff.
http://www.moparts.org/Tech/Archive/motor/36.html
Old Apr 27, 2014 | 07:45 PM
If you can find them ? There were hemi heads made to fit on a 440 block
Stage V ???
Old Apr 27, 2014 | 07:54 PM
Straw43... As far as I know with the Wedge Block... Yes most of that other stuff is Useable....
As for the rest of you..... Stage 5 makes a conversion hemi head for the 440 block.... http://www.stagev.com/pages/hcheads.html
Now back to helping out Straw43... Lets talk Wedge Head 426!!!!
timmie124
May 24, 2011 08:08 AM
gl440
Jun 18, 2010 08:46 AM
MoparMan76
Apr 3, 2010 03:20 PM
Polara_68
Apr 17, 2009 07:48 PM
ramhead
Sep 11, 2008 07:57 PM
