440 6 barrel center carb Problem
Old Jul 27, 2018 | 01:49 PM
gtxguy's Avatar
i bought a OEM 6 barrel assembly for my 69 gtx 440. Original HP 440 engine. It is a auto transmission car. I assembled the thing according to instructions and it runs fantastic at speed. However, it doesn’t like to idle at normal rpm. I have to keep the rpm up around 1400 rpm to keep it running. It chirps pretty good when you put it in gear. This embarrasses me but not much I can do. Is it possible I have a manual center carb and if so, can I modify it to work with my transmission.
Old Jul 27, 2018 | 05:15 PM
Drag Pak's Avatar
Does "original HP 440" mean "no camshaft upgrade"?
Old Jul 27, 2018 | 08:47 PM
I think you have a vacuum leak you need to track down...
Old Jul 28, 2018 | 07:41 AM
gtxguy's Avatar
To the best of my knowledge, the camshaft is original to the car. I bought it in 1999 from a private seller but he was far from the original owner. The odometer showed 4,200 miles when I bought it. I’m pretty sure it had been rebuilt at least once. The car had been in a prop garage in Hollywood for 11 years as it had been used as a prop in 2 made for TV movies from “The Gambler” series starring Kenny Rogers. I may very well have a vacuum problem but the assembly was installed professionally and I assume they would have checked that. They told me I needed a new torque converter. I never could accept that.
Old Jul 28, 2018 | 08:16 AM
Drag Pak's Avatar
like previously mentioned, I would check for a vacuum leak by spraying some cold start around the base of the carbs. I have found six pak manifolds to need severe draw filing to get the surface true for a good carb to manifold seal. Then they need a good wad of sealer on BOTH sides of the thin gasket to get them to seal. The 440 should have enough "at idle grunt" to overcome the need for a smaller torque converter.
See the link for further information.
http://www.mopar1.us/6barreltips.html
Old Jul 28, 2018 | 08:59 PM
Recheck and see if any of the hoses popped off or one of the little rubber caps rotted off or popped off...
But it should not have any trouble idling....
Edward Mayberry
Jan 27, 2015 01:52 PM
Jvz
Oct 1, 2014 07:40 PM
amann99
Feb 28, 2014 06:42 PM
amann99
Feb 28, 2014 04:46 PM
edemestihas
Dec 29, 2011 07:41 AM
