440 drink E85
Old Mar 8, 2019 | 08:28 AM
Apewalski70's Avatar
440 drink E85
Hello everyone.
My 440 have a Holley Sniper EFI (master kit)
https://www.holley.com/products/fuel...parts/550-511K
For run with E85 I up the fuel table to 30%, after 30 miles the sparks plugs look nice and the engine run really great, but I hear a lot of different things about the E85, so my question is simple : what do you thing about a 440 running E85 ? Good or bad ?
Thank you.
Old Mar 8, 2019 | 08:38 AM
Nothing wrong with running "Corn Oil" (E85)... Keeps down detonation and runs a little cooler combustion.. You just have to adjust for the "What you called Fuel Table" to how E85 is blended in your area...
Keep us posted if you have any problems with it?
Old Mar 8, 2019 | 08:44 AM
Thank you, I will change fuel filter after 3 or 4 full tank for keep the fuel pump clean, good to hear that thanks !
Old Mar 8, 2019 | 08:47 AM
I've got a 12.5 440/500" that will be on the streets with e-85, race gas at $10 per gallon just isn't an option. I went with a Holley xp 950 carb that was perfect out of the box. Motor made 645 hp with iron 915 heads. This motor has always been thirsty and for breaking in the cam and four pulls it used 5 gallons of fuel. One thing I would recommend is if you park your car for more than a month run the e85 out of you tank and run strait gas through the fuel system. The alcohol is very corrosive to components in the fuel system.
The 440 in my avatar is a e85 motor....
Old Mar 8, 2019 | 08:53 AM
​​​Nice engine !!!
Okay thanks for the advice.
Old Mar 8, 2019 | 08:54 AM
I have a question for you, what compression ratio do you have?
Old Mar 8, 2019 | 08:58 AM
​​​​​​Didn't have numbers but it's a 73 engine, stock cylinder heads, and this cam :
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=709&sb=2
Never take off the cylinder heads but I think pistons are stock too.
Old Mar 8, 2019 | 09:03 AM
You wont find any extra Fuel Mileage with E85... But it will run cooler and will help with detonation. And yes, the fuel system has to be upgraded and Serviced / Cleaned if it's going to sit and not be used. Must Flush it clean and add a lubricant for storage..
Old Mar 8, 2019 | 09:04 AM
http://www.compcams.com/Company/CC/c...?csid=709&sb=2
So maybe 7.5.1 or 8.0.1 ..... My 2 cents
Old Mar 8, 2019 | 09:10 AM
Is not for fuel mileage but for price, in France '95' octane gasoline price is 1€550, E85 0€60, a full tank cost my 90 euros with 95, or 37 euros with E85.
Yes low comp, I will change pistons (for KB237) and cylinder heads (for Edelbrock RPM), but I need to wait some years for have the money.
Old Mar 8, 2019 | 09:18 AM
Just a question about compression, on the camshaft description, they writed : Needs 9.1 comp.
Did that mean : I need a 9.1 compression engine for use that cam ? Or did the cam give me a 9.1 compression ?
Maybe a stupid question but I speak french and dont really understand this 'needs'
Old Mar 8, 2019 | 09:25 AM
E85 from the pump can support 13.5 to 1 cr, there is no benefit to using it in a low compression motor infact your motor would probably run better on pump gas.
there is a e85 fuel stabiliser available.
Old Mar 8, 2019 | 09:27 AM
What part number Holley Sniper system are you using?
Old Mar 8, 2019 | 09:35 AM
This master kit (fuel line an fuel pump included) :
https://www.holley.com/products/fuel_systems/fuel_injection/sniper_efi/sniper_4bbl_tbi_kits/sniper_4bbl_tbi_master_kits_with_fuel_system/parts/550-511K
Old Mar 8, 2019 | 09:39 AM
Archer's Avatar
A -
Yes, it means the cam will work best with a 9:1 compression ratio.
It will run with lower CRs, but no where near optimally.
Cams cannot change the CR of a motor, but can be configured to best utilize a given CR.
Old Mar 8, 2019 | 09:44 AM
Originally Posted by Archer
A -
Okay it's clear now, thank you !
Old Mar 8, 2019 | 03:37 PM
I took a look at your Beautiful township history... Lovely place you live !!!!! (Belle)
Old Mar 8, 2019 | 05:24 PM
​​​​​​Thank you ! Lot of beautiful roads around here, today I make a run with the Challenger around the montain "Mont Ventoux", good time
Keithb7
May 30, 2017 09:16 PM
jledsome
May 8, 2014 06:33 PM
pro-tech
22
Sep 4, 2013 10:15 PM
Gorts 5th
Aug 17, 2012 01:41 PM
48Plymouth
Jan 28, 2010 06:55 PM
