440 idle problems
Old Oct 9, 2011 | 08:51 AM
mopar777's Avatar
440 idle problems
good afternoon everyone
i took the car out the other night and started to have some problems.
once it got warmed up
it would cruise fine around 40. fine on the expressway. no issues at all.
but at a light the car would start to bog down and idle very weakly and eventually die out if i didnt rev it up.
car sits and doesnt die out in park though
i know the carb is pretty ratty on it. a little leaky from time to time.
does this sound like a carb problem? like its just seen its last day
Old Oct 10, 2011 | 05:45 AM
JS23's Avatar
check your oil.
I once had a Holley carb that leaked so much gas into the manifold it added 3-4 quarts into the crankcase. The crankshaft was swimming.
Old Oct 10, 2011 | 07:40 AM
Commando's Avatar
That sounds like a vacuum leak, or a poorly adjusted carb, actually could be a number of things, hows the timing, all plugs firing?
Old Oct 10, 2011 | 08:56 AM
Archer's Avatar
777 -
If you're fine at speed, but losing it at idle when hot, I'd check for vacuum leaks first. (What's your vac at idle?)
Assume your curb idle is set high enough? That may only be a problem is you have an automatic choke, as that may mask the problem on a cold start.
xvodysseusvx
Jun 25, 2018 04:38 PM
dodgenut7
May 22, 2011 11:55 AM
ThumperNZ
Apr 15, 2011 10:35 PM
motoadam
Apr 15, 2011 02:08 PM
Newf
Jun 22, 2007 09:44 PM
