451 stroker valve lash
Old Jan 31, 2016 | 09:53 AM
tcgrump's Avatar
Hi guys, don't know what cam is in 451 stroker in 69 Fish I just bought.
Where is a good place to start valve lash- solid lifters. Car is giving me fits with spitting through carb- have tried advancing to no avail. New plugs, wires, distributor, cap, rotor, (electronic ign) no vacuum leaks-Holley 750. Firing order confirmed. Ran car gently through neighborhood then it developed a cough on number 2. Valves and springs good all rockers working. Lash is currently at .018/ .022. seems to be spitting on all cylinders now and not just #2.
Thanks a bunch
TC
Old Jan 31, 2016 | 10:38 AM
Hard to tell with out knowing what the cam grinder wants.... How did you come up with the 18/22...
Here is what Comp Cam said... Just the one I looked up.??????
http://www.compcams.com/Company/CC/c...?csid=738&sb=0
Check and make sure the Dist. Shaft is not bent....
Also Recheck the compression in all cylinders....
Old Jan 31, 2016 | 12:09 PM
tcgrump's Avatar
valve lash
Thanks Bob,
18/22 was consensus #s from other hot rodders, engine builders, etc.
I'll work on car a little more later this week and repost- thanks.
TC
Old Jan 31, 2016 | 12:15 PM
Drag Pak's Avatar
What cylinder heads are on it?
Old Feb 4, 2016 | 01:20 PM
Sounds good for aluminum heads
Mrpyro187
Nov 16, 2012 09:09 AM
Mr. Belvedere II
Jun 21, 2012 09:52 AM
boozy
May 7, 2011 07:21 AM
smackhonda
May 14, 2010 05:30 AM
DUST360
Oct 11, 2009 09:54 AM
