452 heads
452 heads
I have a stock 440 and 2 452 heads. One is in the motor and an extra set that has been ported but don't know anything about it. I have been taking the valves out to get them cleaned and shaved possibly but some of the valves are stuck. Any ideas how to get them out
452 Is a good Head..... But I read your going to boost it!!! Use the preditor head.... Or even a set of Victor's would be good....
I'm not familar with the predator head. Who makes them? My idea was to hand port my 452 and then when I finish building my other block I would use aluminium heads when I boost.
yes... Not sure you need that much of a Cylinder head. But something to throw around.... You might even try B1 Heads... If it fits the program a little better... Just food for thought..
Your 452 heads are a good and desirable part in the Mopar world.
There are Step Pistons available to raise compression with open chamber heads.
https://www.uempistons.com/index.php...a00126b87fac92
Merry Christmas, Dan. Now to go and open presents as the family is waking up.
SillyxMongoose
Aug 11, 2013 06:40 PM
