452 heads
Old Sep 4, 2014 | 05:44 PM
camaro440's Avatar
452 heads
I have a stock 440 and 2 452 heads. One is in the motor and an extra set that has been ported but don't know anything about it. I have been taking the valves out to get them cleaned and shaved possibly but some of the valves are stuck. Any ideas how to get them out
Old Dec 20, 2014 | 03:45 PM
camaro440's Avatar
Bump
Old Dec 20, 2014 | 03:54 PM
Long drift punch... Beat them out and throw them in the trash...
Sound like someone set the heads up wrong on the first go round..
That just my 2 cents....
Old Dec 20, 2014 | 04:01 PM
camaro440's Avatar
What about them being an open chamber? Are they worth my time?
Old Dec 20, 2014 | 05:21 PM
452 Is a good Head..... But I read your going to boost it!!! Use the preditor head.... Or even a set of Victor's would be good....
Old Dec 21, 2014 | 09:41 AM
Drag Pak's Avatar
If the valve stem tips are mushroomed, you may wish to file/grind the tips before removing the valves to prevent cracking the valve guide bosses during removal of the valves.
Old Dec 21, 2014 | 11:30 AM
camaro440's Avatar
I'm not familar with the predator head. Who makes them? My idea was to hand port my 452 and then when I finish building my other block I would use aluminium heads when I boost.
Old Dec 21, 2014 | 11:32 AM
camaro440's Avatar
Thanks. I will try that out. I'm just worried about what I've read about open chamber heads
Old Dec 23, 2014 | 07:14 PM
camaro440's Avatar
Preditor heads are made by Indy correct?
Old Dec 24, 2014 | 12:33 PM
yes... Not sure you need that much of a Cylinder head. But something to throw around.... You might even try B1 Heads... If it fits the program a little better... Just food for thought..
Old Dec 24, 2014 | 08:44 PM
camaro440's Avatar
Those preditor heads what I saw were $5000ish
I'm assuming for both but not sure
Old Dec 25, 2014 | 04:45 AM
Your 452 heads are a good and desirable part in the Mopar world.
There are Step Pistons available to raise compression with open chamber heads.
https://www.uempistons.com/index.php...a00126b87fac92
Merry Christmas, Dan. Now to go and open presents as the family is waking up.
Old Dec 26, 2014 | 05:51 AM
camaro440's Avatar
Merry Christmas. Thanks. I got one set on my motor and another set of 452 just sitting around
Old Dec 26, 2014 | 10:29 AM
camaro440's Avatar
I've thought about getting mp template and porting it out hat way and do a 30° back cut in the valves. Any thoughts in that idea?
mrzods13
May 21, 2014 03:07 PM
SillyxMongoose
Aug 11, 2013 06:40 PM
Newf Wit a 440
Jan 4, 2012 07:02 PM
Newf Wit a 440
Dec 5, 2011 03:14 PM
mach3107
Feb 8, 2011 05:07 PM
