68 Chrysler B engine Pushrods
Old Mar 16, 2014 | 07:19 AM
mrzods13's Avatar
I was looking at the comp cams pushrods on jegs they have stock length ones that measure 8.575", but I wanted the Mopar P4529557 pushrods, it says 8.57", is there a difference?I measured with a tape measure, I know it is not accurate but mine are just past 8 1/2 inches. They were the original. I just put a comp cams k21-223-4 kit in it well in the process just finished springs.
Old Mar 16, 2014 | 07:54 AM
Your good with those...
Old Mar 16, 2014 | 08:07 AM
mrzods13's Avatar
With the mopar and comp cams?
Old Mar 16, 2014 | 08:53 AM
Mr.4spd's Avatar
Either/or. +\- .005 isn't going to matter to a hydraulic cam. Nice cam selection by the way.
Old Mar 16, 2014 | 08:58 AM
mrzods13's Avatar
Thanks, the springs are really nice with this kit, not crazy about the valve seals but they went on good and fit good. Anyone ever use comp cam pushrods?
Old Mar 16, 2014 | 09:11 AM
Your going to be good with those push rods.....
Yes I have used Comp Cams... At the moment i have there extreme 268H hyd.... It's ok.... No Wow factor... But did not expect it to have....
Old Mar 16, 2014 | 09:48 AM
mrzods13's Avatar
I'm going from 2 barrel to 4 barrel, I will probably notice a small difference. Headers and exhaust. Wanted to keep it to where I could use the stock convertor. Didn't want nothing extreme just a little more pep. Going to port the intake out just getting the burrs and casting marks out, want to make sure the fuel doesn't bead up in the intake.
Fratzog
Feb 22, 2013 12:07 AM
69POLARA383
Jun 26, 2012 05:31 PM
merkfalc
Jan 16, 2012 11:59 AM
Cracocuda
Jul 29, 2010 04:54 PM
67gtxclone
May 2, 2010 09:27 PM
