70 Roadrunner oil pan
Old Apr 13, 2014 | 07:27 PM
usedknobby's Avatar
Looking for some direction on removing oil pan from 440 with engine in the car, need to replace rear main seal. Can it be done or should I bite the bullitt and pull the motor?
Old Apr 13, 2014 | 07:36 PM
inri's Avatar
I think you may need to pull the motor... sorry to hear that. But just to be sure wait for a couple of Mopar experts to respond.
Thanks.
Old Apr 13, 2014 | 07:43 PM
moe7404's Avatar
as best i remember the "C" bodys, and i guess "B" bodys can drop the pan with out completely pulling the engine. but you will have to rotate the crank so the front part is up, so the pan will slide past the "K". or might have to raise the engine off the mount some. be car full dont kack on the balance. i would not raise it to much so as to not strain the hoses ect. i have done it on 1965 300 L 413 with out raising the engine. but dont the differences between the "C" and "B" body / "K"
Old Apr 13, 2014 | 09:11 PM
You can do it in the car...... Just not fun.... I like to take them out for myself..
Old Apr 14, 2014 | 03:12 AM
Mr.4spd's Avatar
Remove the steering linkage and the pan will come out with a moderate amount of cursing. The trans has to come out to do a rear main seal if it's a stick.
Old Jun 3, 2014 | 08:53 AM
Road Chicken's Avatar
Hey Moe, Let me ask you. How do you know if the oil pan on an 440 HP engine, is bigger 6 qt, or it's the regular oil pan. Is there an ID# on the pan itself?? Thank you so much for your time. J.R.
MarkyMark12345
Apr 10, 2009 06:43 PM
dzltd02
Oct 28, 2008 08:25 AM
oilplanet
Mar 29, 2008 11:08 AM
robertoil
Jan 25, 2008 05:34 PM
