Aftermarket air cleaner help
Old May 20, 2023 | 03:56 PM
Dcmurray70's Avatar
I have a 72 Dodge D100 with a 5.2, 318 V8, with an original 2 bbl carb. I’m trying to update look with aftermarket air cleaner and I don’t know what will work. I know you can buy spacers and adapters to adjust diameter on bottom of new air cleaner from 5+ in to 2 5/8 that is the diameter of my carb. Will a 14 in, say Edelbrock air cleaner work if I get the correct adapter? Also, the air vacuum hoses for the stock engine, do I plug or what? Then, the big, aluminum “dryer vent-like hose” on driver side of air cleaner on the stock air cleaner to engine. What do I do with that? I would appreciate the help. Thank you
Old May 20, 2023 | 04:05 PM
Yes Edelbrock might have the adapter you need.
Old May 20, 2023 | 09:07 PM
dodgem880's Avatar
I believe your carburetor is a Carter BBD.
Here is an example of an adapter to switch from 2 5/8 to 5 1/8.
https://www.holley.com/products/fuel...rts/parts/6407
The "dryer hose" is part of a heated intake air system. However, the controls for it are part of the stock air cleaner. Simply remove that hose from the exhaust manifold heat shield.
If you'd like you can read more about that system here.
Old May 22, 2023 | 07:04 PM
Holley might have the part you need…lol
Dcmurray70
May 20, 2023 08:41 AM
2bentrims
Nov 26, 2015 08:36 AM
TGC
Dec 19, 2013 03:10 PM
mopar318
Feb 18, 2013 07:22 PM
BuckNeccid
Nov 3, 2008 02:33 AM
