Needing Head Gaskets that compress to 4.280"
Old May 26, 2023 | 02:34 PM
lahatte's Avatar
When I built my 0.030" over 383 originally I had used Mopar P4349559 gaskets that were said to have a compressed bore diameter of my actual bore size of 4.280". Now I am finding it impossible to find detailed information on head gaskets regarding the compressed bore size.
But I need to remove the heads on this engine (which has not been run), and need new gaskets. The Mopar P4349559 are apparently no longer available.
Unless I am mistaken, the listed bore size is uncompressed, as measured on an unused gasket? I don't have any to check that. If that is correct, then does anyone know how I can find gasket info that will tell me the compressed bore diameter?
Thanks.
Old May 26, 2023 | 07:38 PM
Usually the bore doesn't change.... Just the thickness...
RBLowbucks
Sep 7, 2018 12:12 PM
70newport
Mar 30, 2016 02:54 PM
armeniansdoitbetter
Jul 7, 2015 11:35 AM
aeonmcallister
Feb 4, 2014 11:45 AM
D.j. Kellogg
Mar 19, 2013 10:43 AM
