Needing Head Gaskets that compress to 4.280"
When I built my 0.030" over 383 originally I had used Mopar P4349559 gaskets that were said to have a compressed bore diameter of my actual bore size of 4.280". Now I am finding it impossible to find detailed information on head gaskets regarding the compressed bore size.
But I need to remove the heads on this engine (which has not been run), and need new gaskets. The Mopar P4349559 are apparently no longer available.
Unless I am mistaken, the listed bore size is uncompressed, as measured on an unused gasket? I don't have any to check that. If that is correct, then does anyone know how I can find gasket info that will tell me the compressed bore diameter?
Thanks.
Thanks.
D.j. Kellogg
Mar 19, 2013 10:43 AM
