Car only starts full throttle. 71 dart 318 new carb timing set perfectly.
Old Dec 26, 2021 | 03:36 PM
Icepickchris's Avatar
I bought a new edelbrock installed new intake manifold gaskets. Set timing properly. She idles and accelerates fine. Just to start I have to floor it?
Old Dec 26, 2021 | 04:40 PM
You give it a couple of pumps before trying to start it?
Old Dec 26, 2021 | 07:32 PM
yeah, I’ve tried that
Old Dec 26, 2021 | 07:35 PM
Archer's Avatar
Ice -
In addition to pumping the gas (usually 3-4 times full on a cold start), do you know where your choke is set when cold?
Old Dec 26, 2021 | 08:43 PM
Before installing new carb it would just fire up. But I know the timing was off then. It’s electric choke.can I adjust the electric choke? It does this fully warmed up haven’t cold started it yet. Just got the carb today. Drive to parts store and installed it there . I might put old one back on. See what it does.possibly the carb is too big? Idk it idles and drives way better now.
Old Dec 26, 2021 | 09:16 PM
Is this a Edelbrock carb? If so they are very prone to boiling the fuel in the carb.
Old Dec 27, 2021 | 06:32 AM
Yes,
Yes
Old Dec 27, 2021 | 06:50 AM
What happens is the fuel in the carb boils out after the car is shut off. If you listen you can actually here the fuel percolating in the bowls so when you go to start it it needs to crank over to get more fuel to start.
i cant say thia is definitely the problem with yours but the Edelbrock carbs don't like today's fuels so it happens.
Old Dec 27, 2021 | 06:54 AM
I have an electric fuel pump. So I’ll try letting it fill then pump it a few times see what happens.
Old Dec 27, 2021 | 06:56 AM
It’s always been my understanding that if it’s flooded you floor it while cranking. It seems as though that’s what’s going on. Idk my old carb was edelbrock too.
Old Dec 27, 2021 | 08:12 AM
It could be that the choke is set to tight try backing it off. This is done at the black plastic cup just loosen the three screws and turn it a quarter inch or so.
Old Dec 27, 2021 | 08:29 PM
It fires right up cold. Letting the float bowls fill and pumping doesn’t fix warm starts. Still requires full throttle to start.
Old Dec 29, 2021 | 10:44 AM
After the car has been driven and parked.... Pull the air cleaner off and look down the air horn of the carburetor and look for vapors coming out of the air horn.... Then look down the air horn and see if you see fuel dripping?
Sjzdx
20
Jan 8, 2022 09:03 PM
65fury
Oct 31, 2010 08:52 AM
YellowTruckOfAwsomeness
Feb 24, 2009 01:19 PM
DartConvertible
Jan 20, 2009 06:01 PM
Dart1972
Jun 22, 2008 07:13 PM
