Coolant and rubber chunks in oil
Old Nov 23, 2017 | 05:47 PM
  #31
68monaco383's Avatar
Update
So i put in the ignitor kit, and new cap and a new coil I've got lots of spark from the coil and at the plugs but it still won't start. I also replaced the intake to firewall ground if that makes a difference but I just want to know why this thing won't start. Firing order is correct and when 1st piston is at top dead center the rotor is at number 1 plug wire so everything should work fine it should fire right up also its getting lots of gas too so that's not it. Help quick would be appreciated thanks
Old Nov 23, 2017 | 06:09 PM
  #32
Have you verified spark at the plugs?
And are the plugs wet with fuel?
Old Nov 23, 2017 | 06:11 PM
  #33
Yes
yes of course and I said that too
Old Nov 23, 2017 | 10:02 PM
  #34
Plugs
I forgot no they are not I found that surprising because its getting lots it gas in the carb
Old Nov 24, 2017 | 12:22 PM
  #35
Going to need to make sure the cam has not jumped time?
Old Nov 27, 2017 | 11:36 AM
  #36
Alright
Yes so that would be the same as the chain jumping a tooth? I know the chain isn't broken because the distributor rotor turns with hand cranking. Could it be the carb? I thought the plugs would be wet with all the flooding just from cranking. The carb will flood out but pull a plug and its dry so what's up with that? Thanks
Old Nov 27, 2017 | 03:21 PM
  #37
Yes..
Could be the carb... Are you sure the carb is squirting fuel when working the throttle?
Explain the carb. Flooding out a little better is you can?
Old Nov 27, 2017 | 06:39 PM
  #38
Alright
Yes..
Better explained when I pump the throttle by hand I can see gas spraying into the carb just looking down the primarys so gas is going into the car and a lot of it I have almost all new fuel lines a new fuel pump and filter, there is definitely lots of gas going into the carb. Just from all the cranking and moving the throttle the carb will get very gassy and it will start to leak out the drivers side onto the intake. I believe carter 4 Barrels have a flood vent on that side am I correct? I would think if its getting lots of gas in the plugs would be wet but they are always dry. Maybe something not letting gas into the intake? Original avs carb. Thanks guys.
Old Nov 27, 2017 | 08:10 PM
  #39
OK. Thanks for clearing that up...
Pull the oil Filler Cap off.. Have someone crank the engine over for you... Use a flashlight and look down in the hole and see if you see the rockers move?
Old Nov 29, 2017 | 09:44 AM
  #40
hjc's Avatar
hjc
Are you sure #1 is on the compression stroke and not the exhaust stroke?
Old Nov 29, 2017 | 12:40 PM
  #41
Yes
the rockers are moving yes
  #42
Yes
yes we have checked multiple times this is starting to really confuse me
Old Nov 29, 2017 | 01:02 PM
  #43
My thought is that its flooded, pull the plugs and clean, turn the motor over untill it quits spiting out the plug holes. Put the clean plugs in and see if it will go.
It's just an idea.
Old Dec 6, 2017 | 10:02 AM
  #44
Hmmm alright
It's just an idea.
Well it's worth a try the only thing is when the carb floods I can pull a plug and it will be dry and they are all clean but I'll give it a try. I also got a rebuild kit for the carb so I hope that'll help. Any other imputs appreciated Thanks.
Old Dec 6, 2017 | 02:39 PM
  #45
When your piston is at TDC your rotor should be past number 1, this will make firing of number 1 BTDC (advanced), this should help it fire.
Old Dec 10, 2017 | 12:32 AM
  #46
It runs! Really good too
yep I did that the carb rebuild was the trick then set the timing with the light and runs like a top thanks for the help guys.
Old Dec 10, 2017 | 07:12 AM
  #47
Beauty, thanks for coming back and telling us your solution.
hckrphil
Jun 17, 2014 09:53 AM
Rumblefish318
Jul 31, 2012 06:14 AM
Dave E
Oct 6, 2010 05:12 PM
dzltd02
Oct 28, 2008 08:25 AM
mukky
Aug 7, 2008 09:39 PM
