Dead Cylinders
Old Apr 8, 2021 | 09:02 AM
rocky321's Avatar
Dead Cylinders
69 Charger 440 with electronic ignition conversion. I had a miss and pulled each plug wire at the cap and had no change in idle on cylinders 1,4,6 and 7. Carb was just rebuilt. ??
Old Apr 8, 2021 | 04:53 PM
fivepoint's Avatar
That's a lot of dead cylinders. Before jumping to the carb, I would check the plugs and wires and make sure the firing order and timing is correct. While you have the plugs out, do a compression check on all of the cylinders.
Old Apr 12, 2021 | 10:31 AM
rocky321's Avatar
All that checks out. Has to be the carb. Only thing that was touched. And since its cylinders 1,4,6 and 7, that's one half of the carb. F*&% have to pull apart the carb again!
Old Apr 12, 2021 | 05:45 PM
Do you have spark at every cylinder?
is the bottom of the distributor cap clean and dry?
is there fuel flow in the carb in each venturi?
cuda341
Oct 18, 2018 07:14 AM
traveeee
Sep 3, 2014 02:41 PM
RRinTN
Oct 18, 2012 02:37 AM
dodgeaspenrookie
Jul 23, 2012 12:15 PM
James93726
Nov 11, 2007 10:48 AM
