distributor cap material and conductivity
Old Nov 11, 2017 | 12:50 PM
dodgem880's Avatar
While doing research for HEI retrofitting. I stumbled across a post on a website called 4x4ham.com
Apparently over there they call the HEI mod the "team rush upgrade" it seems.
Anyway, this section caught my eye:
http://www.4x4ham.com/showthread.php...nition-Upgrade
Now, lets talk about the cap material it's self...
Black distributor caps usually use 'Carbon Black'
(Carbon Black = Soot from industrial manufacture, power generation, ect. Common coloring agent for automotive parts like plastic interior parts and tires, distributor caps, ect.)
To color the plastic.
CARBON IS A CONDUCTOR OF ELECTRICITY!
The cap is actually permuting the cross fires and ground fire problems!
If the cap is slick/shiny BLACK plastic, then look for dull, gray 'Carbon Tracks' inside the cap...
They will look like pencil marks or cob webs, just barely visible.
If you find them, YOU HAVE A PROBLEM!
If the cap has conductive carbon black in it, the problem is COMPOUNDED.
By using a COLORED cap (no carbon) and BRASS TERMINALS,
And spreading the terminals and ground access to the distributor housing farther apart, we are GREATLY increasing the chances the spark energy will go to the correct spark plug terminal!
I find this interesting, I assumed the color was purely for marketing purposes but, it has an advantage?
The truck I’m working on has a newer distributor and cap (maybe 2 – 3 years old). The cap is black. I could get a different one. There is a blue cap on rock auto made by United Motor Products part #CC811X. But, is it necessary?
The hei howto over at slantsix.org mentions to make sure the cap is in good condition and using a long tip rotor which has a brass contact 0.060 longer than stock. (NAPA Echlin Part # MO-3000)
ARCHIVE: HEI Electronic Ignition Retrofit How-To
I have purchased the long tip rotor but, am hesitant to install it since there is also a warning that some distributor caps contacts are ground off center, so there is a chance the rotor could hit them. I'm thinking if I can find a junk distributor I can use it to test compatibility between my existing cap and the long tip rotor as I don't feel like pulling mine.
Old Nov 11, 2017 | 05:50 PM
dodgem880's Avatar
I forgot to mention.
The truck has a new sound when it runs with the new ignition. A rapid ticking sound, kinda sounds like an electric motor. It made me think I had left the heater on the first time I started it.
So, I guess I'm hearing either the sparking in the distributor, the coil since I mounted it to the firewall or both?
Old Nov 11, 2017 | 06:46 PM
Or the rotor is now hitting?
Old Nov 11, 2017 | 06:48 PM
dodgem880's Avatar
But, I never changed out the rotor. I haven't even taken the cap off. How can that be?
I'm planning on taking my truck into the shop tomorrow to check out a few little things. I could take the cap off to confirm nothing weird is going on.
Old Nov 11, 2017 | 07:07 PM
Oh... My Bad... Thought you changed the rotor and it started ticking...
I'm back with you now...
Old Nov 12, 2017 | 07:35 PM
dodgem880's Avatar
Well, I worked up the courage to install the long tipped rotor. Trucks still runs fine, nothing bad happened, nothing sounds different. So... Success.
Attached Thumbnails distributor cap material and conductivity-wp_20171112_15_49_29_pro.jpg
Old Nov 13, 2017 | 10:51 AM
Good Job.... Next..
mopars again
Dec 15, 2014 11:21 AM
dreyerot
Dec 2, 2013 12:48 AM
1923tbucket
Apr 19, 2011 10:35 PM
68 Sat
Nov 11, 2008 11:05 AM
coupe3w
Mar 13, 2008 09:38 AM
