E BODY FUEL CELL, GAS TANK SHOW EM
Old Apr 14, 2015 | 06:47 PM
motasupra's Avatar
Hi I'll go first. We want to run on the street and may want to use the stock filler if possible. What worked for you street and track. Post em if you got em. ha ha
Old Apr 15, 2015 | 06:30 PM
motasupra's Avatar
I would like something like this any one have any advise on where to get the parts? Or pic of your set up. Then the question is to run a in tank fuel pump or not. thoughts
Old Apr 15, 2015 | 08:41 PM
Can you still use the Stock location ?????
http://www.tanksinc.com/index.cfm/pa...rod/prd478.htm
At least you could put you ice chest in the back and a couple lawn chairs...
Or Large Capacity ell from jegs or summit will work good....
Old Apr 17, 2015 | 07:48 AM
MoparMania's Avatar
If you haven't bought the fuel cell or a fuel pump I'd say go with a in tank setup. There are a bunch of benefits of the in tank setup like less noise, pump last longer, less fittings to buy, I could go on and on.
66Newport
Nov 18, 2021 09:46 AM
73Satelliteman
Mar 18, 2013 06:19 PM
Rumblefish318
Aug 29, 2012 10:19 AM
JRR
Sep 24, 2010 07:28 PM
RROriginals
Jul 20, 2010 12:08 AM
