Edlebrock 9905 600 CFM Or Edlebrock 1805 650 CFM
Old Feb 21, 2014 | 03:21 AM
mrzods13's Avatar
I have been looking at these two carburetors for my stock 4 barrel intake. 1968 Chrysler Newport 383, here is the intake i have, and i bought the adapter for it already just trying to decide the carburetor. Doing a mild street cam lifters and springs with double roller timing chain.
Old Feb 21, 2014 | 03:45 AM
Go with the 650 600 is too small for the 383. Or even a 700 with a cam and such
Old Feb 21, 2014 | 04:02 AM
mrzods13's Avatar
Thanks
Old Feb 21, 2014 | 12:59 PM
mrzods13's Avatar
How about a Edelbrock 9907 750 CFM, this is the cam kit I am buying maybe this will help. http://www.jegs.com/i/COMP+Cams/249/K21-223-4/10002/-1
Old Feb 21, 2014 | 03:08 PM
moe7404's Avatar
if you use an Edlebrock square bore carb on that maniflod with just a gasket you will have a air leek. and will not run right. you need a steel plate made by Edlebrock with a specl gasket between the plate and manifold. with regular gasket between the plate and carb. Edlebrock can give you better info on this. this IS good setup that Edlebrock has.
Old Feb 21, 2014 | 03:18 PM
mrzods13's Avatar
If you mean the adapter plate I bought one it comes with two gaskets, one for the top and bottom of the plate
Old Feb 21, 2014 | 06:45 PM
moe7404's Avatar
what you have is an adapter. what you need is a 2696 a plate. but check with Edlebrock. i think. the adapter you have will cause air flow trouble. just be sure every surface is sealed. i think the one i listed has a specl gasket that goes on the manifold first. then the plate. then a regular gasket. just check that all surfaces are sealed. what causes this is that the square bore carb has open places on the bottom of the carb that line up to the wall on the side of the manifold. causing air leeks.
Old Feb 21, 2014 | 09:55 PM
mrzods13's Avatar
The one I bought is the 2696, here is the link http://www.jegs.com/i/Edelbrock/350/2696/10002/-1
it is a thick plate and comes with the two gaskets one for the manifold and one for the top of the plate between the carb and plate. The picture is showing the other side of the plate that goes towards the carb.
Old Feb 22, 2014 | 07:10 AM
moe7404's Avatar
if that is the number you got i must have listed the wrong number. ill recheck the number i think you need.
Old Feb 22, 2014 | 07:22 AM
moe7404's Avatar
i think Edlebrock has there part numbers messed up. the one you need might be 2732? it is just a thin plate with a specl gasket. that thick adapter might work. i have used the thin plate it does work. but it needs the specl gasket on the bottom.
Old Feb 22, 2014 | 08:26 AM
mrzods13's Avatar
Ok moe, found it, matches what you said i will try it out thanks, any opinion on the carb edlebrock 1805 650 sound good.
Old Feb 24, 2014 | 07:56 PM
Silverick's Avatar
I'm a fan of the Edelbrock carburetors...
I recently read an article in Mopar Muscle Magazine about the right carb for a 383... And it seems like I remember the article stating that the 650 cfm carb made almost as much power as the larger ones and the overall numbers were more consistent with the smaller carb. The actual gains with the larger cfm carbs were way up at the top end of the RPM scale, and for driveability the smaller carb came out the winner. I was surprised, and I think that this is why I remembered.
I'll see if I can find the article to make sure that I have my facts straight.... lol
Zoomer59
May 23, 2022 06:24 PM
NYCuda
Apr 22, 2015 06:45 PM
Barfly
Jun 9, 2011 06:23 PM
furyaboveall
Apr 3, 2010 03:18 PM
mopsled
Dec 20, 2009 06:43 AM
