Eliminating the Heat Riser
Old Mar 12, 2015 | 10:46 AM
BruceJ's Avatar
From: Ben Lomond California in the beautiful Santa Cruz mtns
I want to remove the heat riser from my '64 Sport Fury with the 318. I understand there are pro's and con's to doing this but I live in an area of the country where cold weather isn't a problem. Besides it's a convertible so cold weather again, is not a problem. Can I get to it by removing the exhaust pipe from the manifold? Also, I thought about temporarily wiring it open. Is open turning the counter weight fully clockwise. Btw I got the valve free but the temp coil must be bad because the counter weight does not move when I gun the engine and sticks closed after a short drive and cannot be moved again until the engine cools. Thanks
Bruce
Old Mar 12, 2015 | 06:45 PM
Remove the header pipe.... Open the valve.... Take your Mig welder and tack weld it open....
Or remove the manifold and cut it out and then weld up the 2 holes on each side.
OR install headers....
Or install a different Manifold and have the muffler shop make the fit...
Love them 64's by the way !!!!!
Old Mar 13, 2015 | 09:07 AM
DDodger's Avatar
Just wire the thing open
Old Mar 13, 2015 | 11:20 PM
BruceJ's Avatar
Here's the rub. I don't know if it's open or not. Like I mentioned I was able to free up the counter weight so I can't tell if the valve is actually opening or closing. What does happen is that the car will run fine until it heats up after driving it 5 miles or so and then runs rough. This didn't happen until I started fooling around with the heat riser. I have all the service records dating back to the day the car was sold and the PO had the same complaint a couple of times through the years and it was always the heat riser.
THE GOOSE
Sep 6, 2009 06:06 PM
scotts74birds
Apr 18, 2009 11:05 AM
Kevin71
Feb 11, 2009 07:51 AM
outdoors724
Feb 8, 2009 05:16 PM
Commando
Oct 23, 2008 08:37 PM
