Flywheel and Flexplate
Old Feb 7, 2018 | 10:01 AM
Frenchy's Avatar
Any advise please on choice of Flywheel for my 505cid stroker (440) hydraulic roller , Edelbrock Alum. heads , etc. 700hp & 660 lb-ft of torque With 3.70 gear M/T 28 x 10.5 . Total weight with driver 3450 lb . Transmisson is 727 ,T/A 3200 stall , reverse patern T/A body valve . The car is mostly street driven with occasional ( 8 - 10 times a year ) at drag strip .
1) Aluminum or Steel ?
2) Weight ?
3) 130 Tooth or 143 or ???
About Flexplate B&M , Mopar , TCI ???
Last edited by Frenchy; Feb 7, 2018 at 10:06 AM. Reason: Wanting to benefit from other people's experience
Old Feb 7, 2018 | 12:35 PM
ATI Should work.... But what ever you get... Make sure it's SFI. Certed....
Old Feb 7, 2018 | 01:15 PM
Frenchy's Avatar
2) Weight ?
Old Feb 8, 2018 | 05:20 AM
I've used B&M and Mopars, no big deal.
Old Feb 8, 2018 | 08:12 AM
Frenchy's Avatar
Talking Correction on my initial thread
Of course i was talking about Flexplate and not Flywheel on my Automatic 727 .
Old Feb 8, 2018 | 08:14 AM
Frenchy's Avatar
Old Feb 8, 2018 | 09:16 AM
Drag Pak's Avatar
Or, ATI
http://www.atiracing.com/products/flexplate/flexplate.htm
Bolt Crank 915558 Chrysler V8 1/2" bolts 130 tooth $279.00
Old Feb 8, 2018 | 11:36 AM
Frenchy's Avatar
Super strong indeed TKS
Old Feb 8, 2018 | 12:18 PM
Probably needs an eight bolt. Every long stroke bb crank I've seen had eight bolts you had better look.
Old Feb 8, 2018 | 06:26 PM
https://www.summitracing.com/parts/m...0608/overview/
SspazZ
Sep 16, 2014 06:16 PM
Taddeo
Jun 17, 2013 11:31 AM
69charger71duster
Mar 3, 2012 12:00 PM
ernzo2
Feb 25, 2012 08:54 PM
D100Guy
Oct 27, 2010 09:13 PM
