Smalblock replacement in a Dodge Van B300 1981
Old Feb 10, 2018 | 01:43 AM
fury69's Avatar
Dear Mopar Lovers
We have to replace the engine in a 1981 Dodge / MOWAG B300 Heavy Duty Van.
Right now there ist a 318 Smallblock with a 727 Automatic Transmission inside
(Engine an Transmission Numbers will follow). So we decided to Replace the 318
with a 360 Engine from www.remanufactured.com.
Does anybody knows if the 318 is fully compatible to replace it with a 360?
And are there differences of the Mopar Smallblock Engines through the Years?
(Transmission Flange, Exhaustcollector Flange, Flywheel ect.?)
Is the Crankshaft Internal or External balanced?
Thanks for Help and additional infos
Sascha
Old Feb 10, 2018 | 09:57 AM
dodgem880's Avatar
Hello
The balancing of the 318 and 360 are different. The 318 is internally balanced and the 360 is externally balanced.
You'll need a different torque converter and harmonic balancer for 360 equipped applications.
I believe the LA engines use different oil pans for car vs truck/van applications. For cars the pan sump is in the front. For trucks/vans the pan sump is in the rear. That's means dip stick are different as well.
Is this a computer controlled engine? If so, you may have to do something there as well but, I'm not sure. If going with a stock carburetor/intake setup. Those are different. The 318s used a Carter BBD and the 360s used a Holley 2210/2245. The carb bolt patterns are different so they are not interchangeable.
I don't know about the exhaust flange.
Old Feb 10, 2018 | 10:44 AM
1 more thing to add... May need yo upgrade the PCM to a 360 format to make sure it will run correct....
Old Feb 13, 2018 | 12:55 AM
fury69's Avatar
Actual Engine and Transmission Numbers:
Engine: 4204230-318-3
Transmission: PK 4058303 59900237
Ryngus
Jul 3, 2018 03:26 PM
ernzo2
Oct 4, 2011 05:27 PM
Randy Hutchings
Jun 30, 2011 05:49 AM
Shawn
Dec 9, 2008 11:22 AM
